如何用scatter实现ro和rw执行域的链接
3554|5
 楼主| bigfacecat 发表于 2008-7-1 15:36 | 显示全部楼层 |阅读模式
BIOSROM&nbsp;0x20000<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;;//**********&nbsp;*******&nbsp;************************<br />&nbsp;&nbsp;&nbsp;&nbsp;;//*&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CODE&nbsp;SECTION<br />&nbsp;&nbsp;&nbsp;&nbsp;;//*******************************************<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;BIOS_RESET&nbsp;0x20000&nbsp;FIXED<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;bios_bootload.o&nbsp;(+RO,&nbsp;+First)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BIOSInit.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RO)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;<br /><br />RAM_OS&nbsp;0x6e000<br />&nbsp;&nbsp;&nbsp;&nbsp;{&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RW,&nbsp;+ZI)<br />&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;<br />}<br /><br />我的写法导致编译器死掉,这是为啥?<br /><br />我是想让生成的可执行文件中RAM_OS数据连到BIOS_RESET&nbsp;之后,请高手指点!<br />
 楼主| bigfacecat 发表于 2008-7-1 17:09 | 显示全部楼层
呜呜
为啥没有人回复哦
阿南 发表于 2008-7-1 17:58 | 显示全部楼层
楼主你用的是NXP和MDK吗?不好意思我没用过,帮不了你.
知道的兄弟,请帮下忙吧,谢谢啦
 楼主| bigfacecat 发表于 2008-7-2 08:43 | 显示全部楼层
我用的是ADS编译器
我用的是ADS编译器<br />知道的XDJM帮忙下哦
Ice_River 发表于 2008-7-2 10:49 | 显示全部楼层
编译器死掉!?
<br />ADS下的分散加载文件应用实例<br />load_region_name&nbsp;&nbsp;start_address&nbsp;|&nbsp;&quot;+&quot;offset&nbsp;&nbsp;[attributes]&nbsp;[max_size]<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;execution_region_name&nbsp;&nbsp;start_address&nbsp;|&nbsp;&quot;+&quot;offset&nbsp;&nbsp;[attributes][max_size]<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;module_select_pattern&nbsp;&nbsp;[&quot;(&quot;(&quot;+&quot;&nbsp;input_section_attr&nbsp;|&nbsp;input_section_pattern)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(][&quot;,&quot;]&nbsp;&quot;+&quot;&nbsp;input_section_attr&nbsp;|&nbsp;&quot;,&quot;&nbsp;input_section_pattern))&nbsp;*&nbsp;&quot;)&quot;]<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br />load_region:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;加载区,用来保存永久性数据(程序和只读变量)的区域;<br />execution_region:&nbsp;&nbsp;执行区,程序执行时,从加载区域将数据复制到相应执行区后才能被正确执行;<br />load_region_name:&nbsp;&nbsp;加载区域名,用于“Linker”区别不同的加载区域,最多31个字符;<br />start_address:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;起始地址,指示区域的首地址;<br />+offset:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;前一个加载区域尾地址+offset&nbsp;做为当前的起始地址,且“offset”应为“0”或“4”的倍数;<br />attributes:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;区域属性,可设置如下属性:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PI&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;与地址无关方式存放;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RELOC&nbsp;&nbsp;&nbsp;&nbsp;重新部署,保留定位信息,以便重新定位该段到新的执行区;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;OVERLAY&nbsp;&nbsp;覆盖,允许多个可执行区域在同一个地址,ADS不支持;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ABSOLUTE&nbsp;绝对地址(默认);<br />max_size:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;该区域的大小;<br />execution_region_name:执行区域名;<br />start_address:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;该执行区的首地址,必须字对齐;<br />+offset:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;前一个执行区域尾地址+offset&nbsp;做为当前的起始地址,且“offset”应为“0”或“4”的倍数;attributes:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;区域属性,可设置如下属性:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PI&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;与地址无关,该区域的代码可任意移动后执行;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;OVERLAY&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;覆盖;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ABSOLUTE&nbsp;&nbsp;&nbsp;&nbsp;绝对地址(默认);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FIXED&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;固定地址;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;UNINIT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;不用初始化该区域的ZI段;<br />module_select_pattern:&nbsp;目标文件滤波器,支持通配符“*”和“?”;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*.o匹配所有目标,*&nbsp;(或“.ANY”)匹配所有目标文件和库。<br />input_section_attr:&nbsp;&nbsp;&nbsp;&nbsp;每个input_section_attr必须跟随在“+”后;且大小写不敏感;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RO-CODE&nbsp;或&nbsp;CODE<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RO-DATA&nbsp;或&nbsp;CONST<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RO或TEXT,&nbsp;selects&nbsp;both&nbsp;RO-CODE&nbsp;and&nbsp;RO-DATA<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RW-DATA<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RW-CODE<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RW&nbsp;或&nbsp;DATA,&nbsp;selects&nbsp;both&nbsp;RW-CODE&nbsp;and&nbsp;RW-DATA<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ZI&nbsp;或&nbsp;BSS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ENTRY,&nbsp;that&nbsp;is&nbsp;a&nbsp;section&nbsp;containing&nbsp;an&nbsp;ENTRY&nbsp;point.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FIRST,用于指定存放在一个执行区域的第一个或最后一个区域;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LAST,同上;<br />input_section_pattern:&nbsp;段名;<br />汇编中指定段:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;vectors,&nbsp;CODE,&nbsp;READONLY<br />C中指定段:<br />#pragma&nbsp;arm&nbsp;section&nbsp;[sort_type][[=]&quot;name&quot;]]&nbsp;[,sort_type=&quot;name&quot;]*<br />sort_type:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;code、rwdata、rodata、zidata<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;如果“sort_type”指定了但没有指定“name”,那么之前的修改的段名将被恢复成默认值。<br />#pragma&nbsp;arm&nbsp;section&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;恢复所有段名为默认设置。<br />应用:<br />&nbsp;&nbsp;&nbsp;&nbsp;#pragma&nbsp;arm&nbsp;section&nbsp;rwdata&nbsp;=&nbsp;&quot;SRAM&quot;,zidata&nbsp;=&nbsp;&quot;SRAM&quot;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;static&nbsp;OS_STK&nbsp;&nbsp;SecondTaskStk[256];&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;“rwdata”“zidata”将定位在“sram”段中。<br />&nbsp;&nbsp;&nbsp;&nbsp;#pragma&nbsp;arm&nbsp;section&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;恢复默认设置<br />分散加载文件中定义如下:<br />&nbsp;&nbsp;&nbsp;&nbsp;Exec_Sram&nbsp;&nbsp;0x80000000&nbsp;&nbsp;0x40000<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(sram)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />“PI”&nbsp;属性使用示例:<br />LR_1&nbsp;0x010000&nbsp;PI&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;first&nbsp;load&nbsp;region&nbsp;is&nbsp;at&nbsp;0x010000.<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_RO&nbsp;+0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;PI&nbsp;attribute&nbsp;is&nbsp;inherited&nbsp;from&nbsp;parent.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;default&nbsp;execution&nbsp;address&nbsp;is&nbsp;0x010000,&nbsp;but&nbsp;the&nbsp;code&nbsp;can&nbsp;be&nbsp;moved.<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+RO)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;All&nbsp;the&nbsp;RO&nbsp;sections&nbsp;go&nbsp;here.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_RW&nbsp;+0&nbsp;ABSOLUTE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;PI&nbsp;attribute&nbsp;is&nbsp;overridden&nbsp;by&nbsp;ABSOLUTE.<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+RW)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;RW&nbsp;sections&nbsp;are&nbsp;placed&nbsp;next.&nbsp;They&nbsp;cannot&nbsp;be&nbsp;moved.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_ZI&nbsp;+0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;ER_ZI&nbsp;region&nbsp;placed&nbsp;after&nbsp;ER_RW&nbsp;region.<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+ZI)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;All&nbsp;the&nbsp;ZI&nbsp;sections&nbsp;are&nbsp;placed&nbsp;consecutively&nbsp;here.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br />LR_1&nbsp;0x010000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;first&nbsp;load&nbsp;region&nbsp;is&nbsp;at&nbsp;0x010000.<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_RO&nbsp;+0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;Default&nbsp;ABSOLUTE&nbsp;attribute&nbsp;is&nbsp;inherited&nbsp;from&nbsp;parent.&nbsp;The&nbsp;execution&nbsp;address<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;is&nbsp;0x010000.&nbsp;The&nbsp;code&nbsp;and&nbsp;ro&nbsp;data&nbsp;cannot&nbsp;be&nbsp;moved.<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+RO)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;All&nbsp;the&nbsp;RO&nbsp;sections&nbsp;go&nbsp;here.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_RW&nbsp;0x018000&nbsp;PI&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;PI&nbsp;attribute&nbsp;overrides&nbsp;ABSOLUTE<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+RW)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;The&nbsp;RW&nbsp;sections&nbsp;are&nbsp;placed&nbsp;at&nbsp;0x018000&nbsp;and&nbsp;they&nbsp;can&nbsp;be&nbsp;moved.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;ER_ZI&nbsp;+0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;ER_ZI&nbsp;region&nbsp;placed&nbsp;after&nbsp;ER_RW&nbsp;region.<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*(+ZI)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;All&nbsp;the&nbsp;ZI&nbsp;sections&nbsp;are&nbsp;placed&nbsp;consecutively&nbsp;here.<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br />
 楼主| bigfacecat 发表于 2008-7-2 17:25 | 显示全部楼层
谢谢大哥
谢谢大哥<br />能不能辛苦再帮我看看我的写法有没有问题<br />ADS每次快链接完的时候,就飞了,程序窗口就不见了。<br />。。。。<br />好奇怪额
