注解2440启动代码!!!!!!!!!
2218|1
真白菜|  楼主 | 2008-8-19 21:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
 帮我注解2440启动代码!!!!!!!!!
 PRESERVE8
; Area Definition and Entry Point
;  Startup Code must be linked first at Address at which it expects to run.
                AREA    RESET, CODE, READONLY
                ARM
; Exception Vectors
;  Mapped to Address 0.
;  Absolute addressing mode must be used.
;  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors         LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            ; Reserved Vector
                LDR     PC, IRQ_Addr
                LDR     PC, FIQ_Addr
                IF      IntVT_SETUP <> 0
;Interrupt Vector Table Address
HandleEINT0          EQU    IntVTAddress
HandleEINT1          EQU    IntVTAddress +4
HandleEINT2          EQU    IntVTAddress +4*2
HandleEINT3          EQU    IntVTAddress +4*3
HandleEINT4_7      EQU    IntVTAddress +4*4
HandleEINT8_23    EQU    IntVTAddress +4*5
HandleCAM          EQU    IntVTAddress +4*6
HandleBATFLT      EQU    IntVTAddress +4*7
HandleTICK          EQU    IntVTAddress +4*8
HandleWDT          EQU    IntVTAddress +4*9
HandleTIMER0       EQU    IntVTAddress +4*10
HandleTIMER1       EQU    IntVTAddress +4*11
HandleTIMER2       EQU    IntVTAddress +4*12
HandleTIMER3       EQU    IntVTAddress +4*13
HandleTIMER4       EQU    IntVTAddress +4*14
HandleUART2        EQU    IntVTAddress +4*15
HandleLCD           EQU    IntVTAddress +4*16
HandleDMA0          EQU    IntVTAddress +4*17
HandleDMA1          EQU    IntVTAddress +4*18
HandleDMA2          EQU    IntVTAddress +4*19
HandleDMA3          EQU    IntVTAddress +4*20
HandleMMC          EQU    IntVTAddress +4*21
HandleSPI0          EQU    IntVTAddress +4*22
HandleUART1          EQU    IntVTAddress +4*23
HandleNFCON          EQU    IntVTAddress +4*24
HandleUSBD          EQU    IntVTAddress +4*25
HandleUSBH          EQU    IntVTAddress +4*26
HandleIIC          EQU    IntVTAddress +4*27
HandleUART0       EQU    IntVTAddress +4*28
HandleSPI1           EQU    IntVTAddress +4*39
HandleRTC           EQU    IntVTAddress +4*30
HandleADC           EQU    IntVTAddress +4*31
IRQ_Entry
                sub    sp,sp,#4       ;reserved for PC
                stmfd    sp!,{r8-r9}
                ldr    r9,=INTOFFSET
                ldr    r9,[r9]
                ldr    r8,=HandleEINT0
                add    r8,r8,r9,lsl #2
                ldr    r8,[r8]
                str    r8,[sp,#8]
                ldmfd    sp!,{r8-r9,pc}
                ENDIF
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD     0                      ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
Undef_Handler   B       Undef_Handler
SWI_Handler     B       SWI_Handler
PAbt_Handler    B       PAbt_Handler
DAbt_Handler    B       DAbt_Handler
                IF      IntVT_SETUP <> 1
IRQ_Handler     B       IRQ_Handler
                ENDIF
                IF      IntVT_SETUP <> 0
IRQ_Handler     B       IRQ_Entry
                ENDIF
FIQ_Handler     B       FIQ_Handler
; Memory Controller Configuration
                IF      MC_SETUP <> 0
MC_CFG
                DCD     BWSCON_Val
                DCD     BANKCON0_Val
                DCD     BANKCON1_Val
                DCD     BANKCON2_Val
                DCD     BANKCON3_Val
                DCD     BANKCON4_Val
                DCD     BANKCON5_Val
                DCD     BANKCON6_Val
                DCD     BANKCON7_Val
                DCD     REFRESH_Val
                DCD     BANKSIZE_Val
                DCD     MRSRB6_Val
                DCD     MRSRB7_Val
                ENDIF
; Clock Management Configuration
                IF      CLOCK_SETUP <> 0
CLK_CFG
                DCD     LOCKTIME_Val
                DCD     CLKDIVN_Val
                DCD     UPLLCON_Val
                DCD     MPLLCON_Val
                DCD     CLKSLOW_Val
                DCD     CLKCON_Val
                DCD     CAMDIVN_Val
                ENDIF
; I/O Configuration
                IF      PIO_SETUP <> 0
PIOA_CFG
                DCD     PCONA_Val
PIOB_CFG        DCD     PCONB_Val
                DCD     PUPB_Val
PIOC_CFG        DCD     PCONC_Val
                DCD     PUPC_Val
PIOD_CFG        DCD     PCOND_Val
                DCD     PUPD_Val
PIOE_CFG        DCD     PCONE_Val
                DCD     PUPE_Val
PIOF_CFG        DCD     PCONF_Val
                DCD     PUPF_Val
PIOG_CFG        DCD     PCONG_Val
                DCD     PUPG_Val
PIOH_CFG        DCD     PCONH_Val
                DCD     PUPH_Val
PIOJ_CFG        DCD     PCONJ_Val
                DCD     PUPJ_Val
                ENDIF
; Reset Handler
                EXPORT  Reset_Handler
Reset_Handler
                IF      WT_SETUP <> 0
                LDR     R0, =WT_BASE
                LDR     R1, =WTCON_Val
                LDR     R2, =WTDAT_Val
                STR     R2, [R0, #WTCNT_OFS]
                STR     R2, [R0, #WTDAT_OFS]
                STR     R1, [R0, #WTCON_OFS]
                ENDIF
                IF      CLOCK_SETUP <> 0
                LDR     R0, =CLK_BASE
                ADR     R8, CLK_CFG
                LDMIA   R8, {R1-R7}
                STR     R1, [R0, #LOCKTIME_OFS]
                STR     R2, [R0, #CLKDIVN_OFS]
                STR     R3, [R0, #UPLLCON_OFS]
                nop
                nop
                nop
                nop
                nop
                nop
                nop
                STR     R4, [R0, #MPLLCON_OFS]
                STR     R5, [R0, #CLKSLOW_OFS]
                STR     R6, [R0, #CLKCON_OFS]
                STR     R7, [R0, #CAMDIVN_OFS]
                ENDIF
                IF      MC_SETUP <> 0
                ADR     R13, MC_CFG
                LDMIA   R13, {R0-R12}
                LDR     R13, =MC_BASE
                STMIA   R13, {R0-R12}
                ENDIF
                IF      PIO_SETUP <> 0
                LDR     R13, =PIO_BASE
                IF      PIOA_SETUP <> 0
                ADR     R0, PIOA_CFG
                STR     R0, [R13, #PCONA_OFS]
                ENDIF
                IF      PIOB_SETUP <> 0
                ADR     R0, PIOB_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONB_OFS]
                STR     R1, [R13, #PUPB_OFS]
                ENDIF
                IF      PIOC_SETUP <> 0
                ADR     R0, PIOC_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONC_OFS]
                STR     R1, [R13, #PUPC_OFS]
                ENDIF
                IF      PIOD_SETUP <> 0
                ADR     R0, PIOD_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCOND_OFS]
                STR     R1, [R13, #PUPD_OFS]
                ENDIF
                IF      PIOE_SETUP <> 0
                ADR     R0, PIOE_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONE_OFS]
                STR     R1, [R13, #PUPE_OFS]
                ENDIF
                IF      PIOF_SETUP <> 0
                ADR     R0, PIOF_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONF_OFS]
                STR     R1, [R13, #PUPF_OFS]
                ENDIF
                IF      PIOG_SETUP <> 0
                ADR     R0, PIOG_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONG_OFS]
                STR     R1, [R13, #PUPG_OFS]
                ENDIF
                IF      PIOH_SETUP <> 0
                ADR     R0, PIOH_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONH_OFS]
                STR     R1, [R13, #PUPH_OFS]
                ENDIF
                IF      PIOJ_SETUP <> 0
                ADR     R0, PIOJ_CFG
                LDR     R1, [R0,#4]
                STR     R0, [R13, #PCONJ_OFS]
                STR     R1, [R13, #PUPJ_OFS]
                ENDIF
                ENDIF
; Setup Stack for each mode
                LDR     R0, =Stack_Top
;  Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
;  Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
;  Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
;  Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
;  Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
;                IMPORT MMU_EnableICache
;                bl     MMU_EnableICache
;  Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                MOV     SP, R0
                SUB     SL, SP, #USR_Stack_Size
; Enter the C code
                IMPORT  __main
                LDR     R0, =__main
                BX      R0
; User Initial Stack & Heap
                AREA    |.text|, CODE, READONLY
               ; IMPORT  __use_two_region_memory
                EXPORT  __user_initial_stackheap
                LDR     R0, =  Heap_Mem
                LDR     R1, =(Stack_Mem + USR_Stack_Size)
                LDR     R2, = (Heap_Mem +      Heap_Size)
                LDR     R3, = Stack_Mem
                BX      LR
                END
Ice_River| | 2008-8-20 08:44 | 只看该作者
自己研究吧!
网上很多这样的**!
