[i.MX] fsl-yocto-3.14.28-1.0.0编译error-glibc_2.20.bb failed
4275|4
 楼主| wugang137 发表于 2015-5-15 14:31 | 显示全部楼层 |阅读模式
fsl-yocto-3.14.28-1.0.0编译模块过程中,出现错误:
| /home/wugang/fsl-release-bsp/build-wayland/tmp/sysroots/x86_64-linux/usr/libexec/arm-poky-linux-gnueabi.gcc-cross-initial-arm/gcc/arm-poky-linux-gnueabi/4.9.1/ld:/home/wugang/fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/glibc/2.20-r0/build-arm-poky-linux-gnueabi/shlib.lds:150: syntax error
| collect2: error: ld returned 1 exit status
| make[2]: *** [/home/wugang/fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/glibc/2.20-r0/build-arm-poky-linux-gnueabi/libc.so] Error 1
| make[2]: Leaving directory `/home/wugang/fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/glibc/2.20-r0/git/elf'
| make[1]: *** [elf/subdir_lib] Error 2
| make[1]: Leaving directory `/home/wugang/fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/glibc/2.20-r0/git'
| make: *** [all] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/wugang/fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/glibc/2.20-r0/temp/log.do_compile.10254)
ERROR: Task 120 (/home/wugang/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.20.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 445 tasks of which 415 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
有人知道怎么解决么?谢谢
FSL_TICS_Rita 发表于 2015-6-17 17:30 | 显示全部楼层
非常感谢你的技术问题。我们建议您将此i.mx的技术问题提交到飞思卡尔的英文论坛。网址是https://community.freescale.com/welcome 谢谢。
mini1986 发表于 2015-6-18 08:50 | 显示全部楼层
关注一下......
