[USB驱动]
USB HUB 问题
5301|2
cecwxf|  楼主 | 2015-5-21 15:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi all
目前有个USB 的问题。
1.USB hub插入 Host设备后,刚开始一段时间 工作是正常的,但是过2分钟后,HUB这边就不能识别了,后续插入HUB,DP端都会被拉成2.9V的电压,而不是一个脉冲。
2.然后获取描述符时一直会timeout。
DP一直为高 会是怎么造成了?拔出来后,当然为低了,只是插进去 不是一个脉冲,无法握手。
[  157.906043] usb 1-1: usb-storage timed out on ep0out len=0/0
[  157.910723] hub 1-1:1.0: cannot reset port 3 (err = -110)
[  157.916123] hub 1-1:1.0: port 3 not enabled, trying reset again...
[  158.946778] usb 1-1: usb-storage timed out on ep0out len=0/0
[  158.952693] hub 1-1:1.0: cannot reset port 3 (err = -110)
[  158.957060] hub 1-1:1.0: port 3 not enabled, trying reset again...
[  159.987049] usb 1-1: usb-storage timed out on ep0out len=0/0
[  159.992683] hub 1-1:1.0: cannot reset port 3 (err = -110)
[  159.997075] hub 1-1:1.0: port 3 not enabled, trying reset again...
[  161.027654] usb 1-1: usb-storage timed out on ep0out len=0/0
[  161.032589] hub 1-1:1.0: cannot reset port 3 (err = -110)
[  161.037679] hub 1-1:1.0: port 3 not enabled, trying reset again...
[  161.043945] hub 1-1:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[  162.067290] usb 1-1: usb-storage timed out on ep0out len=0/0
[  162.072155] hub 1-1:1.0: cannot disable port 3 (err = -110)
[  162.077496] hub 1-1:1.0: logical disconnect on port 3
[  163.107589] usb 1-1: usb-storage timed out on ep0out len=0/0
[  163.112312] hub 1-1:1.0: cannot disable port 3 (err = -110)
[  163.118335] hub 1-1:1.0: state 7 ports 4 chg 0008 evt 0000
cecwxf|  楼主 | 2015-6-7 22:41 | 只看该作者
时钟不对,结贴。
Zev| | 2015-6-10 22:35 | 只看该作者
ISP1507A1HNTM  QFN-32 有需要的+我QQ:823569333
个人签名:充实灵魂,满足自己。做生活的强者,当时代的勇士!!!
