[STM32F4] 定时器捕获脉冲计数
2652|11
 楼主| tobyking 发表于 2015-5-21 16:49 | 显示全部楼层 |阅读模式
各位大侠,下面是小弟的程序,小弟初学者,刚用定时器没几天,刚学会产生PWM波形, 看看我的为啥检测不到脉冲的输入呢?
我用TIM3产生PWM波形,直接输入到TIM4的CH2,想让pulse_numb_min = TIM_GetCapture2(TIM4)收集到一些脉冲数量,请问我要怎么改?
unsigned int pulse_numb_min=0,pulse_count;
/* Private variables ---------------------------------------------------------*/
TIM_ICInitTypeDef  TIM_ICInitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
/* Private function prototypes -----------------------------------------------*/
void RCC_Config(void);
void GPIO_Config(void);
void NVIC_Config(void);
//void LED_Configuration(void);
//extern u8 CAPTURE_STA;
int main(void)
  /* System Clocks Configuration */
  RCC_Config();
  /* NVIC configuration */
  NVIC_Config();
  /* Configure the GPIO ports */
  GPIO_Config();
  TIM3_GPIO_Config();//PWM²¨ÐÎÊä³ö¹Ü½ÅÅäÖÃ
        TIM3_Mode_Config(222,121);//˫·PWM²¨ÐβúÉú£¬Õ¼¿Õ±ÈÉèÖÃ
        LED_Configuration( );
  TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Period = 999;    //
  TIM_TimeBaseStructure.TIM_Prescaler = 83;  //1MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;//ͨµÀ2
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //ÉÏÉýÑØ´¥·¢
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;//²»ÓÃÂ˲¨Æ÷
  TIM_ICInit(TIM4, &TIM_ICInitStructure);
  //´¥·¢Æ÷TIM4
  TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2); //Ñ¡ÔñIC2ΪʼÖÕ´¥·¢Ô´
  TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);//TIM´Óģʽ£º´¥·¢ÐźŵÄÉÏÉýÑØÖØÐ³õʼ»¯¼ÆÊýÆ÷ºÍ´¥·¢¼Ä´æÆ÷µÄ¸üÐÂʼþ
  TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable); //Æô¶¯¶¨Ê±Æ÷µÄ±»¶¯´¥·¢
  /* TIM enable counter */
  TIM_Cmd(TIM4, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TIM_ITConfig(TIM4, TIM_IT_CC2, ENABLE);//ʹÄÜÖжÏ
                while( 1 )
                                        if(pulse_numb_min >= 50 )
                                        LED1_OFF;
//ÒÔÉÏÊÇÖ÷³ÌÐò²¿·Ö//
/************ÖжÏÀïÃæ×öµÄÊÂÇé**************/
extern unsigned int pulse_numb_min;
void TIM4_IRQHandler(void)
                if( TIM_GetITStatus(TIM4,TIM_FLAG_CC2)== SET )
                                pulse_numb_min = TIM_GetCapture2(TIM4);
                        TIM_ClearITPendingBit(TIM4, TIM_IT_CC2);  //Çå³ýTIMµÄÖжϴý´¦Àíλ
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_AHB2PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  /* TIM4 channel 2 pin (PB.07) configuration */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//¸¡¿ÕÊäÈë
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable the TIM3 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
fanxsd 发表于 2015-5-21 16:51 | 显示全部楼层
楼主最好看看 官方的实例。还是比较的简单的。
 楼主| tobyking 发表于 2015-5-21 16:54 | 显示全部楼层
我是初学者,刚学两个月呢,零基础,现在也只能勉强改改管脚配置,算算定时周期什么的
luofeng2g 发表于 2015-5-21 17:17 | 显示全部楼层
按照例程来配置,一步步来!
fanxsd 发表于 2015-5-21 17:22 | 显示全部楼层
我是初学者,刚学两个月呢,零基础,现在也只能勉强改改管脚配置,算算定时周期什么的 ...
那更应该看了,自己搞懂了。是质的飞跃啊!
 楼主| tobyking 发表于 2015-5-21 17:25 | 显示全部楼层
求例程啊,我已经看了很多了,参考了很多
 楼主| tobyking 发表于 2015-5-21 17:26 | 显示全部楼层
按照例程来配置,一步步来!
已经参考了很多,我都快能把它背下来了,还是不行,求靠谱些的例程
luofeng2g 发表于 2015-5-21 17:28 | 显示全部楼层
官方例程?如果这还不靠谱。。。。。那我也不知道还有什么靠谱的
fanxsd 发表于 2015-5-21 17:35 | 显示全部楼层
表皮 肤浅
冰河w 发表于 2015-5-21 19:37 | 显示全部楼层
定时器捕获功能设置对了吗
评分
参与人数 1威望 +1 收起 理由
tobyking + 1 淡定
查看全部评分
 楼主| tobyking 发表于 2015-5-22 08:31 | 显示全部楼层
定时器捕获功能设置对了吗
查了很多遍,没问题啊
liuliuzhou 发表于 2015-7-21 17:03 | 显示全部楼层
求问官方实例在哪?
