最近用AT91SAM7X256的SPI总线,想自己管理器件的CS线,只用芯片提供的MOSI、MISO和SCK进行数据收发,硬件安排为器件片选PA14(SPI0_NPCS2),使用SPI0。程序如下,但是读出的结果总是不对的。<br /><br />初始化如下:<br />void SPI_init(void)<br />{<br /> AT91C_BASE_PMC->PMC_PCER = (1 << AT91C_ID_SPI0);<br /> AT91C_BASE_PIOA->PIO_PDR = BSP_GPIOA_SPI0;<br /> AT91C_BASE_SPI0->SPI_CR = AT91C_SPI_SWRST;<br /> AT91C_BASE_SPI0->SPI_MR = AT91C_SPI_MSTR | AT91C_SPI_FDIV | AT91C_SPI_PS_VARIABLE | AT91C_SPI_MODFDIS | AT91C_SPI_DLYBCS;<br /> AT91C_BASE_SPI0->SPI_CSR[2] = AT91C_SPI_CPOL | AT91C_SPI_DLYBS | AT91C_SPI_DLYBCT | AT91C_SPI_SCBR | AT91C_SPI_BITS_8;<br /> AT91C_BASE_SPI0->SPI_CR = AT91C_SPI_SPIEN;<br /><br />//片选 <br /> AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_PIOA;<br /> AT91C_BASE_PIOA->PIO_PER = BSP_GPIOA_TEMP;<br /> AT91C_BASE_PIOA->PIO_OER = BSP_GPIOA_TEMP;<br /> AT91C_BASE_PIOA->PIO_IDR = BSP_GPIOA_TEMP;<br /> AT91C_BASE_PIOA->PIO_SODR = BSP_GPIOA_TEMP;<br />}<br /><br />//发送字节<br />void SPI_SendByte(CPU_INT08U data)<br />{<br /> CPU_INT32U value_for_cs;<br /> value_for_cs = (~(1 << 2)) & 0xF; //Place a zero among a 4 ONEs number<br /> AT91C_BASE_SPI0->SPI_TDR = ((CPU_INT32U)data & 0x000000FF) | (value_for_cs << 16);<br /> while((AT91C_BASE_SPI0->SPI_SR & AT91C_SPI_TXEMPTY == 0)) {<br /> ;<br /> }<br />}<br /><br />//读取字节<br />CPU_INT32U SPI_RecByte(void)<br />{<br /> return((CPU_INT08U)(AT91C_BASE_SPI0->SPI_RDR & 0xFFFF));<br />}<br /><br />进行读写操作时,片选我保证了有效。<br />因为第一次用,所以都摸不着头脑了。恳请有经验的朋友帮忙看看哪里出问题了,谢谢。 |
