[i.MX] 编译uboot出错,怎么解决,求助
3419|4
 楼主| kaikaisi 发表于 2015-6-4 10:57 | 显示全部楼层 |阅读模式
/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/pkg-config-0.28/glib/glib/gthread-posix.c:1175:10: error: 'PR_SET_NAME' undeclared (first use in this function)
| /home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/pkg-config-0.28/glib/glib/gthread-posix.c:1175:10: note: each undeclared identifier is reported only once for each function it appears in
| make[6]: *** [gthread-posix.lo] Error 1
| make[6]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build/glib/glib'
| make[5]: *** [all-recursive] Error 1
| make[5]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build/glib/glib'
| make[4]: *** [all] Error 2
| make[4]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build/glib/glib'
| make[3]: *** [all-recursive] Error 1
| make[3]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build/glib'
| make[2]: *** [all] Error 2
| make[2]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build/glib'
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory `/home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/build'
| make: *** [all] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/kaikai/fsl-release-bsp/yocto_learn/tmp/work/i686-linux/pkgconfig-native/0.28-r0/temp/log.do_compile.7118)
ERROR: Task 193 (virtual:native:/home/kaikai/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_0.28.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 85 tasks of which 82 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
mini1986 发表于 2015-6-4 12:42 | 显示全部楼层
像是少了某个头文件,网上搜搜吧。最好用国外的搜索引擎......
 楼主| kaikaisi 发表于 2015-6-8 11:32 | 显示全部楼层
gthread-posix.c:1175:10: error: 'PR_SET_NAME' undeclared (first use in this function)是这个函数中的一个宏好像没有定义申请,但找不到函数所以不知到怎么定义,不知道是不是这个错误导致的编译不过啊!请知道一下,谢谢。
mini1986 发表于 2015-6-8 12:21 | 显示全部楼层
网上搜搜啊,没遇到过......
FSL_TICS_Rita 发表于 2015-7-14 11:19 | 显示全部楼层
非常感谢你的技术问题。我们建议您将此i.mx的技术问题提交到飞思卡尔的英文论坛。网址是https://community.freescale.com/welcome 谢谢。
