什么是Component呀
842|10
guoyt|  楼主 | 2015-6-7 20:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这两天刚看psoc3,总看到Component,到底什么是Component呀
hanwe| | 2015-6-7 20:27 | 只看该作者
我一般翻译成组件或元件,几乎所有单片机内部都会集成一些功能组件
guoyt|  楼主 | 2015-6-7 20:28 | 只看该作者
能举个例子吗?
hanwe| | 2015-6-7 20:28 | 只看该作者
例如ADC,UART,USB等等啊
yufe| | 2015-6-7 20:28 | 只看该作者
PSOC里的组件库是我见过最为丰富的
llia| | 2015-6-7 20:28 | 只看该作者
而且这些组件可以自由选用
yufe| | 2015-6-7 20:29 | 只看该作者
并且所选组件之间的路由也是非常灵活的
wangpe| | 2015-6-7 20:29 | 只看该作者
说的是,psoc有很多可编程的数字和模拟资源,可以设计成你所需要的Component元件,这就是psoc的魅力之处。
langgq| | 2015-6-7 20:29 | 只看该作者
要是用过psoc1的话,和user module类似。
wangzsa| | 2015-6-7 20:29 | 只看该作者
官方解释:
A component is similar to a fixed function peripheral found in traditional microcontrollers. The components support many of the common microcontroller peripherals such as ADC, DAC, I2C, and SPI as well as application specific features such as LCDs, bootloaders and LED control. The advantage of PSoC is that you have the ability to place and configure the components on the target device. Instead of choosing a device for its features, PSoC embedded developers can tailor PSoC to fit their application. PSoC Creator supports a mixed signal environment providing both digital and analog components. Creator comes equipped with extensible code for each component in the form of APIs. The component APIs provide out-of-the-box code that allows the user to implement peripheral actions using simple function calls reducing development time. For more information on each component see the component datasheet that details the functionality, APIs, and specifications.
guoyt|  楼主 | 2015-6-7 20:30 | 只看该作者
多谢大家指点
