| 参考
 * Function Name: customize_itoa
 * Summary:
 *    This is a simple function to convert int to ascii code
 * Parameters:
 * Return:
 char *customize_itoa(int num,char *str,int radix)
 char index[]="0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ";
 unsigned unum;
 int i=0,j,k;
 if(radix==10&&num<0)
 unum=(unsigned)-num;
 str[i++]='-';
 else unum=(unsigned)num;
 do
 str[i++]=index[unum%(unsigned)radix];
 unum/=radix;
 }while(unum);
 str[i]='\0';
 if(str[0]=='-') k=1;
 else k=0;
 char temp;
 for(j=k;j<=(i-k-1)/2.0;j++)
 temp=str[j];
 str[j]=str[i-j-1];
 str[i-j-1]=temp;
 return str;
