[ZLG-ARM] 在Keil内调用Flash Magic命令行Flash ISP的应用方法(菜农实验)
4582|3
 楼主| hotpower 发表于 2007-3-9 12:53 | 显示全部楼层 |阅读模式
在Keil内调用Flash&nbsp;Magic命令行Flash&nbsp;ISP的应用方法(菜农三八节劳动实验):<br />1.在Tools菜单内打开Customize&nbsp;Tools&nbsp;Menu...<br />2.在Menu&nbsp;Content内加入&nbsp;<br />&nbsp;&nbsp;Program&nbsp;device&nbsp;with&nbsp;%H<br />3.在Command内加入<br />&nbsp;&nbsp;D:Program&nbsp;FilesFlash&nbsp;MagicFM.EXE<br />4.在Arguments内加入参数(擦除整片,烧写程序,加密/不加密,校验)<br />a)Flash不加密<br />&nbsp;&nbsp;DEVICE(LPC2138,&nbsp;11.0592)&nbsp;COM(1,28800)&nbsp;HARDWARE(BOOTEXEC,&nbsp;25,&nbsp;250)&nbsp;ERASE(DEVICE,&nbsp;PROTECTISP)&nbsp;HEXFILE(#H,&nbsp;NOCHECKSUMS,&nbsp;NOFILL,&nbsp;PROTECTISP)&nbsp;VERIFY(#H,&nbsp;NOCHECKSUMS)<br />b)Flash加密<br />&nbsp;&nbsp;DEVICE(LPC2138,&nbsp;11.0592)&nbsp;COM(1,28800)&nbsp;HARDWARE(BOOTEXEC,&nbsp;25,&nbsp;250)&nbsp;ERASE(DEVICE,&nbsp;PROTECTISP)&nbsp;HEXFILE(#H,&nbsp;NOCHECKSUMS,&nbsp;NOFILL,&nbsp;PROTECTISP,&nbsp;CODEREADPROTECTION)&nbsp;VERIFY(#H,&nbsp;NOCHECKSUMS)<br />5.选中Run&nbsp;Minimized时DOS界面最小化<br />6.在Tools菜单内运行Program&nbsp;device&nbsp;with&nbsp;RTC.HEX(注:本例为RTC.HEX)<br /><br /><br />如果COM口不存在或在使用,则运行结果如下:<br />&quot;D:Program&nbsp;FilesFlash&nbsp;MagicFM.EXE&quot;&nbsp;DEVICE(LPC2138,&nbsp;11.0592)&nbsp;COM(1,28800)&nbsp;HARDWARE(BOOTEXEC,&nbsp;50,&nbsp;250)&nbsp;ERASE(DEVICE,&nbsp;PROTECTISP)&nbsp;HEXFILE(D:LPC**RTCRTC.HEX,&nbsp;CHECKSUMS,&nbsp;NOFILL,&nbsp;PROTECTISP,&nbsp;CODEREADPROTECTION)<br />Flash&nbsp;Magic&nbsp;Version&nbsp;3.50.197<br />8051/XA&nbsp;Driver&nbsp;Version&nbsp;2.31.196<br />ARM&nbsp;Driver&nbsp;Version&nbsp;1.23.196<br />(C)&nbsp;Embedded&nbsp;Systems&nbsp;Academy&nbsp;2000-2007&nbsp;All&nbsp;rights&nbsp;reserved<br />Connection&nbsp;failed:&nbsp;COM&nbsp;Port&nbsp;error<br /><br />如果COM口存在且未使用,则运行结果如下:<br />&quot;D:Program&nbsp;FilesFlash&nbsp;MagicFM.EXE&quot;&nbsp;DEVICE(LPC2138,&nbsp;11.0592)&nbsp;COM(1,28800)&nbsp;HARDWARE(BOOTEXEC,&nbsp;50,&nbsp;250)&nbsp;ERASE(DEVICE,&nbsp;PROTECTISP)&nbsp;HEXFILE(D:LPC**RTCRTC.HEX,&nbsp;CHECKSUMS,&nbsp;NOFILL,&nbsp;PROTECTISP,&nbsp;CODEREADPROTECTION)<br />Flash&nbsp;Magic&nbsp;Version&nbsp;3.50.197<br />8051/XA&nbsp;Driver&nbsp;Version&nbsp;2.31.196<br />ARM&nbsp;Driver&nbsp;Version&nbsp;1.23.196<br />(C)&nbsp;Embedded&nbsp;Systems&nbsp;Academy&nbsp;2000-2007&nbsp;All&nbsp;rights&nbsp;reserved<br />Connected<br />Device&nbsp;selected<br />Erase&nbsp;complete&nbsp;(DEVICE)<br />Hex&nbsp;file&nbsp;programming&nbsp;complete&nbsp;(D:LPC**RTCRTC.HEX)<br />Verify&nbsp;passed&nbsp;(D:LPC**RTCRTC.HEX)<br /><br />菜地公告:引用本文必须注明出处!!!<br /><br />雁塔菜农HotPower&nbsp;&nbsp;2007.3.8&nbsp;于西安大雁塔菜地&nbsp;http://HotPower.21ic.org/<br />
 楼主| hotpower 发表于 2007-3-9 18:35 | 显示全部楼层
Flash Magic命令行非常简单,远程下载将会很方便
<br /> 相关链接:<a href='http://blog.21ic.com/user1/46/archives/2006/32352.html'>http://blog.21ic.com/user1/46/archives/2006/32352.html</a>
王紫豪 发表于 2007-3-9 20:52 | 显示全部楼层
我要去菜地里面偷西红柿了,注意了啊
 楼主| hotpower 发表于 2007-3-9 21:03 | 显示全部楼层
哈哈~~~改天有空做个用命令行的带系列号功能的ISP
套FM比自己做要简单多了~~~不过那个T1,T2太晕!!!
