大家好,我用的是STM32F207芯片,在直流充电桩上面应用。芯片的两个CAN口都被利用到了。
目前出现的问题是:其中一路和电动汽车BMS通信的CAN口的中断在启动前期可以进入中断,到某一时候(大约可以收到90多帧数据)(未知),CAN中断突然进不去了,其他中断正常。而且该CAN口重新初始化之后又可以进入,但是会重复之前的现象。
CAN设置如下:
CAN_FilterConfTypeDef  sFilterConfig;
  static CanTxMsgTypeDef        TxMessage1;
  static CanRxMsgTypeDef        RxMessage1;
  CanHandleToBMS.Instance = CAN1;
  CanHandleToBMS.pTxMsg = &TxMessage1;
  CanHandleToBMS.pRxMsg = &RxMessage1;
        //CAN 初始化 30MHz 250kbps
  CanHandleToBMS.Init.TTCM = DISABLE;
  CanHandleToBMS.Init.ABOM = DISABLE;
  CanHandleToBMS.Init.AWUM = DISABLE;
  CanHandleToBMS.Init.NART = DISABLE;
  CanHandleToBMS.Init.RFLM = DISABLE;
  CanHandleToBMS.Init.TXFP = DISABLE;
  CanHandleToBMS.Init.Mode = CAN_MODE_NORMAL;
  CanHandleToBMS.Init.SJW = CAN_SJW_1TQ;
  CanHandleToBMS.Init.BS1 = CAN_BS1_6TQ;
  CanHandleToBMS.Init.BS2 = CAN_BS2_8TQ;
  CanHandleToBMS.Init.Prescaler = 8;
  HAL_CAN_Init(&CanHandleToBMS);
        //CAN过滤器
  /*##-2- Configure the CAN Filter ###########################################*/
  sFilterConfig.FilterNumber = 0;
  sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
  sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
  sFilterConfig.FilterIdHigh = 0x0000;
  sFilterConfig.FilterIdLow = 0x0000;
  sFilterConfig.FilterMaskIdHigh = 0x0000;
  sFilterConfig.FilterMaskIdLow = 0x0000;
  sFilterConfig.FilterFIFOAssignment = CAN_FIFO0;
  sFilterConfig.FilterActivation = ENABLE;
  sFilterConfig.BankNumber = 14;
  HAL_CAN_ConfigFilter(&CanHandleToBMS, &sFilterConfig);
CAN回调函数如下:
        if(CanHandle->pRxMsg->IDE == CAN_ID_EXT)   //判断扩展帧
                if(CanHandle->Instance == CAN1)  //判断BMS的CAN进入中断
                        CANBMS.IDE = CanHandle->pRxMsg->ExtId;
                        CANBMS.DLC = CanHandle->pRxMsg->DLC;
                        for(i=0;i<8;i++)
                                CANBMS.Data = CanHandle->pRxMsg->Data;
                        CANqueue_push(CANBMS);
                        HAL_CAN_Receive_IT(CanHandle, CAN_FIFO0);
不知道大家有没有出现类似的问题,谢谢 |
