28335内部AD采集问题
904|0
 楼主| lanmeng1989 发表于 2015-6-19 17:05 | 显示全部楼层 |阅读模式
我采集出来的数据不是顶部失真,就是底部失真;   我设置峰峰值为2V,直流偏置1V,fs=300Hz时出现顶部失真,而且按照转换公式D=(A-参考值)*4096/3计算的话也该是2730,而在变量表中显示的最大值是4095,求大神指教。下面配置AD的主要程序   AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;      // 值是2   AdcRegs.ADCTRL1.bit.CPS=1
   AdcRegs.ADCTRL1.bit.CPS=1        ;
   AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;  // 值是f   Sequential mode: Sample rate   = 1/[(2+ACQ_PS)*ADC clock in ns]
                        //                     = 1/(3*40ns) =8.3MHz (for 150 MHz SYSCLKOUT)
                                            //                     = 1/(3*80ns) =4.17MHz (for 100 MHz SYSCLKOUT)
   AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;        // 1  Cascaded mode    级联
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x1;  // 选择通道00   即ADCINA0
   AdcRegs.ADCTRL1.bit.CONT_RUN = 1;       // Setup continuous run 连续运行模式
   AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;       // Enable Sequencer override feature
   AdcRegs.ADCCHSELSEQ1.all = 0x0;         // Initialize all ADC channel selects to A0
   AdcRegs.ADCCHSELSEQ2.all = 0x0;
   AdcRegs.ADCCHSELSEQ3.all = 0x0;
   AdcRegs.ADCCHSELSEQ4.all = 0x0;
   AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x1;  // convert and store in 8 results registers
