[ZLG-ARM] 求助:求个CrossWorks for ARM 1_6 Evaluation Registration
2161|1
 楼主| ATmega16 发表于 2007-7-29 16:21 | 显示全部楼层 |阅读模式
I would like to evaluate CrossWorks for 30 days. My evaluation registration key is:08M2X-5H11N-6VIDI-OEOMO-4STX9-MVJVZ-G2522-ADF4W-6EQ49-36OUW+8XMHU-HUDGC-3A110-T1EGC-97O2S-WSZV0-L4YDL-9WQUL-892X7-UBRQXI understand that this is for evaluation only and must not be used for commercial purposes.Thanks.
lordor 发表于 2007-7-29 16:59 | 显示全部楼层
网上可以找到
网上可以找到一个注册时间为1年的注册码
