[ZLG-ARM] zlg的arm7仿真时总是进入异常中断死循环
2244|0
 楼主| dzwmcu 发表于 2007-6-10 12:32 | 显示全部楼层 |阅读模式
1.&nbsp;在ads中仿真,会警告:<br />&nbsp;&nbsp;you&nbsp;were&nbsp;trying&nbsp;to&nbsp;set&nbsp;a&nbsp;breakpoint&nbsp;om&nbsp;prolessor&nbsp;ARM7TDMI-S&nbsp;at&nbsp;address&nbsp;0x14&nbsp;or&nbsp;were&nbsp;stepping/running&nbsp;to&nbsp;this&nbsp;adress.this&nbsp;adress&nbsp;is&nbsp;located&nbsp;in&nbsp;a&nbsp;literal&nbsp;pool<br />&nbsp;&nbsp;&nbsp;ABORT&nbsp;&nbsp;-do&nbsp;not&nbsp;set&nbsp;the&nbsp;breakpoint<br />&nbsp;&nbsp;&nbsp;RETRY&nbsp;&nbsp;-set&nbsp;the&nbsp;breakpoint&nbsp;on&nbsp;this&nbsp;occasion&nbsp;and&nbsp;show&nbsp;this&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;warning&nbsp;&nbsp;infutrue<br />&nbsp;&nbsp;&nbsp;IGNORE&nbsp;-set&nbsp;the&nbsp;breakpoint&nbsp;and&nbsp;do&nbsp;not&nbsp;show&nbsp;this&nbsp;warning&nbsp;in&nbsp;future<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;终止&nbsp;&nbsp;&nbsp;重试&nbsp;&nbsp;忽略<br /><br />2.全速运行到main()函数处停下,但接着单步运行时,会进不了所有的子函数,且好象不是在仿真(因对端口操作不起作用,万用表量无效),但是每单步一次,光标也会跟着移动,<br /><br /><br />&nbsp;&nbsp;&nbsp;&nbsp;急死我了!急死我了!急死我了!<br />&nbsp;&nbsp;&nbsp;&nbsp;救命了!
