[嵌入式linux] ubuntu编译ltib出错
971|2
 楼主| yeyangyun 发表于 2015-6-26 10:00 | 显示全部楼层 |阅读模式
collect2: ld returned 1 exit status
make: *** [mconf] Error 1
error: Bad exit status from /home/zc/ltib-mpc8536rdk-20100630/tmp/rpm-tmp.31362 (%build)
RPM build errors:
Build time for lkc: 3 seconds
Failed building lkc
Died at ./ltib line 1384.
traceback:
main::build_host_rpms:1384
  main::host_checks:1439
   main:542
Started: Wed Jan 21 17:40:00 2015
Ended:   Wed Jan 21 17:50:18 2015
Elapsed: 618 seconds
These packages failed to build:
lkc
Build Failed
错误如上,不知道怎么弄,刚开始接手,请问下大家怎么改?
我的是MPC8536
用的ubuntu12.04,32位
 楼主| yeyangyun 发表于 2015-6-29 21:38 | 显示全部楼层
ambercctv 发表于 2015-6-27 10:00
./ltib -m scbuild -p kernel 吗?
已经解决了,没有下载patch-ltib-ubuntu12.04.sh才导致lkc建立失败
mini1986 发表于 2015-6-30 08:55 | 显示全部楼层
关注一下......
