DSP6713做bootload时程序编译正常,但是out文件无法load,提示data verification failed at address 0x90000000. please verify target memory and memory map, 如下图,在网上找了很长时间都不行,下面的是我的CMD文件,请大家帮我看看
MEMORY
BOOTRAM: o = 00000000h l = 00000400h
IRAM: o = 00000400h l = 0000FA00h
CE0: o = 80000000h l = 01000000h
FLASH_BOOT: o = 0x90000000 l = 00000400h
FLASH_REST: o = 0x90000400 l = 0001FC00h
SECTIONS
.boot_load : load = FLASH_BOOT, run = BOOTRAM
/* Initialized User Code Section */
.text : load = FLASH_REST, run = IRAM
LOAD_START(_text_ld_start),
RUN_START(_text_rn_start),
SIZE(_text_size)
/* This is also a special initialized data section, which could stay
in ROM, however probably not desirable, due to Slow ROM access times.
const values never change, by definition. */
.cinit > FLASH_REST
.const > IRAM
.stack > IRAM
.bss > IRAM
.data > IRAM
.far > IRAM
.switch > IRAM
.sysmem > IRAM
.cio > IRAM
