大家好,
目前搭建ltib出现点问题,希望版主帮忙看看。
./ltib
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path. Please
install/upgrade these packages on your host. If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package Minimum ver Installed info
glibc-devel 0 not installed
zlib 0 not installed
Died at ./ltib line 1397.
traceback:
main::host_checks:1397
main:542
Started: Tue Jun 30 15:39:59 2015
Ended: Tue Jun 30 15:39:59 2015
Elapsed: 0 seconds
Build Failed
Exiting on error or interrupt
这里显示缺失两个文件,然后我执行sudo apt-get install glibc-devel zlib
[sudo] password for yv:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package glibc-devel
E: Unable to locate package zlib
谁遇到过相同的问题,帮忙解决下, 不胜感激。 |
