[ZLG-ARM]
axd调试错误
2639|1
zhuguoxi|  楼主 | 2007-9-3 10:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
axd调试,debuginram,单步执行到main函数末尾就出现错误提示:DBT Warning 00135: <tag "ErrMess_BPinLitPool" not found - message file did not open>
请问各位大虾,这是怎么回事?谢谢
int main (void)
    uint8 uc1;//,tempbuf[5];
    // LED ON
    ALARM_LED_ON();
    RF0_LED_ON();
    RF1_LED_ON();
    // status code
    equipstatus = 0xf7;
    // pconp config
    pconp_config();
    // io config
    pin_config();
    // alarm
    // kout = 0
    PIN_KOUT_CLR();
    // rtc
    rtc_enable();
    // i2c config
//    i2c_config(I2CMODE_MT);
    // rs485
    RS485_config();
    // spi config
    spi_config(SPI0);
//    spi_config(SPI1);
    // rfchip set as std mode
    rfchipinit(RFCHIP0);
//    rfchipinit(RFCHIP1);
    // 参数初始化,初始化或读出EEPROM中的参数
    //    paraminit();
    // __test
    // 参数初始化
    readerwiredaddr = READERIDL_DEF;
    taggroupid = TAGIDH_DEF;
    tagofflinetime = TAGOFFLINETIME_DEF;
    baudratecode = BAUDRATECODE_DEF;
    rfch = RFCH_DEFAULT;
    readeridl = READERIDL_DEF;
    // uart0
    uart0_config(baudratecode);
    // timer0
    timer0_config();
    // inter rtc init
    // equipstatus.b3
    //    if( !interrtc_init() )
    // __test
    DOW = DS_DAY_DEF;
    DOM = DS_DATE_DEF;
    MONTH = DS_MONTH_DEF;
    YEAR = DS_YEAR_DEF;
    SEC = DS_SECOND_DEF;
    MIN = DS_MINUTE_DEF;
    HOUR = DS_HOUR_DEF;
    equipstatus &= ~EQUIPSTATUS_BIT_RTCREAD;
            // irq init
    irqinit();
    // reset status
    sendabyteto485bus(equipstatus);
    // LED OFF
    //ALARM_LED_OFF();
    //RF0_LED_OFF();
    //RF1_LED_OFF();
    while(1)
sendabyteto485bus(0x33);
        // ext wdt
        externwdt_tiggle();
        // set rfchip mode
        // internal wdt
        wdt_feed();
sendabyteto485bus(0x34);
        // tag test end,come back to normal
        if( (tagtestsign == TAGTEST_STA) && (tagtesttime_min == MIN) && (tagtesttime_sec == SEC) )
            tagtestsign = TAGTEST_END;
        else if( (tagtestsign == TAGTEST_END) && (tagtestovertime_min == MIN) && (tagtestovertime_sec == SEC) )
            tagtestsign = TAGTEST_NO;
            taginfo_wrptr_head = 0;
            taginfo_wrptr_end = 0;
            taginfo_rdptr = 0;
        // key live time
        if( key )
            if( keylivetime <= SEC )
                uc1 = SEC - keylivetime;
            else
                uc1 = 60 + SEC - keylivetime;
            if( uc1 >= KEY_LIVETIME_DEF )
                key = 0;
        // ad,extern power
//        inpower = adc(AIN0)/4;
sendabyteto485bus(0x35);
        // in alarm
        if( PIN_KIN_IOPIN() )
            inalarm = TRUE;
        else
            inalarm = FALSE;
        sendabyteto485bus(0x55);
    return 0;
zlgARM| | 2007-9-3 13:38 | 只看该作者
zhuguoxi
您好:
  建议您用百度搜索一下错误代码,有相当多的解答。
