[资料分享与下载] [转载](Kinetis K60)UART之“说好的寄存器呢”
1171|1
 楼主| lovecat2015 发表于 2015-7-8 09:09 | 显示全部楼层 |阅读模式
串口初始化……
main.c 文件
#include "common.h"
#include "uart.h"
#include "isr.h"
void UART4_Init(U32);
void delay(long count);
void Uart4_SendByte(U8 Char);
void main (void)
  char str[]="hello cortex-m4  ";
  U8 i;
  DisableInterrupts;
  UART4_Init(57600);
  EnableInterrupts;
  while(1)
    for(i=0; str!=''; i++)
      Uart4_SendByte(str);
    delay(7000000);
  while(count--)
      asm("nop");
void UART4_Init(U32 BaudRate)
  U16 ubd, brfa;
  U8 temp;
  PORTC_PCR15 = PORT_PCR_MUX(0x3);   //引脚使能
  PORTC_PCR14 = PORT_PCR_MUX(0x3);
  SIM_SCGC1 |= SIM_SCGC1_UART4_MASK;   //时钟使能
  UART4_C2 &= ~((1<<2) | (1<<3)); //禁止发送接收   控制寄存器C2
  UART4_C1 = 0;  //控制器C1 全部使用默认配备
  ubd = (U16)((50000000)/(BaudRate * 16));   //波特率设置
  UART4_BDH = (U8)ubd>>8;
  UART4_BDL = (U8)(ubd);
  brfa = (((50000000)/(BaudRate * 16)) - (ubd * 32));  //波特率微调 1/32的增量
  temp = UART4_C4 & ~(UART_C4_BRFA(0x1F));
  UART4_C4 = temp | UART_C4_BRFA(brfa);
  UART4_C2 |= ((1<<2) | (1<<3));  //允许发送接收
  return;
    while(!(UART_S1_REG(UART4_BASE_PTR) & UART_S1_TDRE_MASK)); //UARTx_S1状态寄存器
    UART4_D = Char;
    return;
isr.h文件
#ifndef EnableInterrupts
#define EnableInterrupts asm(" CPSIE i");  //开总中断
#endif
#ifndef DisableInterrupts
#define DisableInterrupts asm(" CPSID i");  //关总中断
#endif
typedef unsigned short    U16;
typedef unsigned long     U32;
typedef unsigned char     U8;
串口接收函数
U8 Uart4_Receive(void)
    U8 Receivechar;
    while(!(UART_S1_REG(UART4_BASE_PTR) & UART_S1_RDRF_MASK));       //查询是否接受到数据
    Receivechar  =   UART4_D;                    //接受到8位的数据
    return(Receivechar);
dirtwillfly 发表于 2015-7-8 11:51 | 显示全部楼层
楼主,你的图全挂了
