[Atmel] Atmel 5V Cortex-M0+ 单片机介绍
1876|3
 楼主| ddllxxrr 发表于 2015-7-8 20:19 | 显示全部楼层 |阅读模式
The Atmel® | SMART SAM C ARM® Cortex®-M0+ based microcontroller (MCU) series builds on decades of innovation and experience in embedded Flash microcontroller technology. It not only sets a new benchmark for flexibility and ease-of-use but also combines the performance and energy efficiency of an ARM Cortex-M0+ based MCU with an optimized architecture and peripheral set. Atmel | SMART SAM C devices are truly differentiated 5V microcontrollers that are ideal for home appliances, industrial control and other 5V applications.
Key Features
  • 2.7V – 5.5V Operating Voltage — Ensures best possible signal-to-noise ratio and robustness in term of noise immunity, EMC, ESD and latch up.
  • Atmel® QTouch® Peripheral Touch Controller — Offers built-in hardware support for buttons, sliders, wheels and proximity, and supports both mutual- and self-capacitive touch without the need for external components. It delivers superb sensitivity and noise tolerance, as well as self-calibration, making any user tuning superfluous.
  • Peripheral Flexibility — An innovative serial communication module (SERCOM) is fully software-configurable to handle I2C, USART/UART, SPI, RS485 and LIN communications. With multiple SERCOM modules on a device, you can tailor the peripheral mix precisely to your application.
  • CAN BUS — The SAM C21 series provides two Controller Area Network (CAN) modules supporting CAN 2.0A/B and CAN-FD 1.0.
  • DMA — The SAM C20 series features a 6-channel DMA controller supporting both memory and peripheral data transfers, while the SAM C21 features a 12-channel DMA controller.
  • Scalability — Flash memory densities range from 32KB to 256KB with packages ranging from 32- to 64-pin options.
Harvard 发表于 2015-7-8 23:44 | 显示全部楼层
不知道价格怎么样 如果能杀入5块区间 还是比较给力的
 楼主| ddllxxrr 发表于 2015-7-9 11:37 | 显示全部楼层
恩,我也希望越便宜越好
菁菁木华1 发表于 2015-8-16 20:01 | 显示全部楼层
加油加油加油加油加油加油
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
