[STM32F1]
USB例程的问题
874|3
JY-DX-JY|  楼主 | 2015-7-10 13:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
USB, ST, ck, AC, se
* Function Name  : USB_Istr
* Description    : STR events interrupt service routine
* Input          :
* Output         :
* Return         :
void USB_Istr(void)
  wIstr = _GetISTR();
#if (IMR_MSK & ISTR_RESET)
  if (wIstr & ISTR_RESET & wInterrupt_Mask)        //这个是复位吧
    _SetISTR((u16)CLR_RESET);
    Device_Property.Reset();
#ifdef RESET_CALLBACK
    RESET_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_DOVR)        //这个是什么意思
  if (wIstr & ISTR_DOVR & wInterrupt_Mask)
    _SetISTR((u16)CLR_DOVR);
#ifdef DOVR_CALLBACK
    DOVR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ERR)        //这个是错误
  if (wIstr & ISTR_ERR & wInterrupt_Mask)
    _SetISTR((u16)CLR_ERR);
#ifdef ERR_CALLBACK
    ERR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_WKUP)        //这个是唤醒
  if (wIstr & ISTR_WKUP & wInterrupt_Mask)
    _SetISTR((u16)CLR_WKUP);
    Resume(RESUME_EXTERNAL);
#ifdef WKUP_CALLBACK
    WKUP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SUSP)        //这个是悬挂的意思吧?
  if (wIstr & ISTR_SUSP & wInterrupt_Mask)
    /* check if SUSPEND is possible */
    if (fSuspendEnabled)
      Suspend();
    else
      /* if not possible then resume after xx ms */
      Resume(RESUME_LATER);
    /* clear of the ISTR bit must be done after setting of CNTR_FSUSP */
    _SetISTR((u16)CLR_SUSP);
#ifdef SUSP_CALLBACK
    SUSP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SOF)        //这个是什么意思?
  if (wIstr & ISTR_SOF & wInterrupt_Mask)
    _SetISTR((u16)CLR_SOF);
    bIntPackSOF++;
#ifdef SOF_CALLBACK
    SOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ESOF)        //这个又是什么意思
  if (wIstr & ISTR_ESOF & wInterrupt_Mask)
    _SetISTR((u16)CLR_ESOF);
    /* resume handling timing is made with ESOFs */
    Resume(RESUME_ESOF); /* request without change of the machine state */
#ifdef ESOF_CALLBACK
    ESOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_CTR)        //这个也不明白
  if (wIstr & ISTR_CTR & wInterrupt_Mask)
    /* servicing of the endpoint correct transfer interrupt */
    /* clear of the CTR flag into the sub */
    CTR_LP();
#ifdef CTR_CALLBACK
    CTR_Callback();
#endif
#endif
} /* USB_Istr */
我在STM32F103       USB例程里看到USB中断里的一段程序,看不太懂。
请高手指教,谢谢!
JY-DX-JY|  楼主 | 2015-7-10 14:28 | 只看该作者
高手支招啊!
soso1217| | 2015-7-10 20:32 | 只看该作者
去看芯片资料寄存器介绍啊
JY-DX-JY|  楼主 | 2015-7-10 20:54 | 只看该作者
这也看不出来是那个寄存器呀!
个人签名:晴天响霹雳,平地一声雷。
245
