[i.MX] MFGtool工具下载androi.d4.4.2有问题
3604|8
 楼主| rencwang 发表于 2015-7-12 00:24 | 显示全部楼层 |阅读模式
AN, TI, ce, ev, boot
我的开发板是i.mx6DL SabreSD. 在板子刚下来时,做了400M DDR压力测试,正常通过,使用Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER 下载程序到emmc中,发现到"access boot partition 1"时出错,在串口中查看发现报如下错误:
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
16+0 records in
16+0 records out
8192 bytes (8.0KB) copied, 0.000264 seconds, 29.6MB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
utp_poll: pass returned.
UTP: received command '$ echo 0 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 0 > /sys/block/mmcblk0boot0/force_ro"
sh: can't create /sys/block/mmcblk0boot0/force_ro: nonexistent directory
UTP: sending Non-success to kernel for command $ echo 0 > /sys/block/mmcblk0boot0/force_ro.
utp_poll: exit with status 256
我在ucl2.xml中Android-SabreSD-eMMC下注释掉
<CMD state="Updater" type="push" body="$ echo 0 > /sys/block/mmcblk0boot0/force_ro">access boot partition 1</CMD>
<CMD state="Updater" type="push" body="$ echo 1 > /sys/block/mmcblk0boot0/force_ro"> re-enable read-only access</CMD>后,
报这个错can't create /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config: nonexistent directory
一起注释掉<CMD state="Updater" type="push" body="$ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config">enable boot partion 1 to boot</CMD>后
跑到 “Partitioning...”出错,错误信息如下:
Warning: /dev/mmcblk0 is not a block device
Disk /dev/mmcblk0: cannot get geometry
Disk /dev/mmcblk0: 0 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
sfdisk: Partition 1 does not exist, cannot change it
PS:我新板子emmc是使用的SD4_DATA0到SD4_DATA7,SD4_CMD,SD4_CLK,是不是需要在mfg工具中修改u-boot-mx6dl-sabresd.bin和uImage?
PS:几块板子都出现这样的问题,应该不是硬件问题吧!
不知道我描述的是否清楚,如有不正确,请批评指正,谢谢!
打赏榜单
xyz549040622 打赏了 1.00 元 2015-07-15
 楼主| rencwang 发表于 2015-7-12 16:49 | 显示全部楼层
在    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>下面添加如下命令:
        <CMD state="Updater" type="push" body="$ ls -l /dev/mmc* ">ls /dev/*</CMD>
查看串口没有mmcblk0设备结点。
请问哪位高手碰到过类似的问题,该怎么解决?谢谢!
小猫爱吃鱼 发表于 2015-7-12 21:48 | 显示全部楼层
在     Jumping to OS image. 下面添加如下命令:
        ls /dev/*
查看串口没有mmcblk0设备结点。
没有弄过啊,不是太懂,帮楼主顶一下吧
xyz549040622 发表于 2015-7-15 10:29 | 显示全部楼层
发帖有奖,希望常来21ic提问呦
znning 发表于 2015-7-15 11:10 | 显示全部楼层
先在Uboot看下设备有没有识别吧。或者先用SD卡启动试试看!
评分
参与人数 1威望 +1 收起 理由
rencwang + 1 是先用sd卡启动之后再去对比问题.
查看全部评分
mini1986 发表于 2015-7-21 09:58 | 显示全部楼层
还没用过MFGtool,一直都是用SD卡调的,有空学习学习......
 楼主| rencwang 发表于 2015-7-26 21:22 | 显示全部楼层
问题解决了,没找到emmc是硬件问题,后面在ucl2.xml中修改了烧录分区能启动了!谢谢各位给的答复
Luis德华 发表于 2015-7-27 08:24 | 显示全部楼层
看看Uboot下设备有没有识别
FSL_TICS_Rita 发表于 2015-8-5 16:03 | 显示全部楼层
恭喜楼主问题已经解决,欢迎有问题继续在本论坛中交流讨论。
