[Kinetis] 咨询K60里ADC16的自动校准使用
1257|2
 楼主| ronczch1 发表于 2015-7-13 16:57 | 显示全部楼层 |阅读模式
我看到官网例程里,采集0电平值之后,通过读取正端校准寄存器和负端校准寄存器之后,计算平均值,为何直接写入到ADC_PG和ADC_MG这两个寄存器去了,这两个寄存器似乎是个和增益有关的寄存器,不明白为何这样设置。
奥德赛 发表于 2015-7-14 09:03 | 显示全部楼层
是不是只有写入这两个寄存器才能校准呢
FSL_TICS_ZJJ 发表于 2015-7-16 16:54 | 显示全部楼层
关于这个问题,楼主可以看K60的用户手册,在ADC的校正功能那里讲的很清楚。
35.4.7 Calibration function
The ADC contains a self-calibration function that is required to achieve the specified
accuracy. Calibration must be run, or valid calibration values written, after any reset and
before a conversion is initiated. The calibration function sets the offset calibration value,
the minus-side calibration values, and the plus-side calibration values. The offset
calibration value is automatically stored in the ADC offset correction register (OFS), and
the plus-side and minus-side calibration values are automatically stored in the ADC plusside
and minus-side calibration registers, CLPx and CLMx. The user must configure the
ADC correctly prior to calibration, and must generate the plus-side and minus-side gain
calibration results and store them in the ADC plus-side gain register (PG) after the
calibration function completes.
To complete calibration, the user must generate the gain calibration values using the
following procedure:
1. Initialize or clear a 16-bit variable in RAM.
2. Add the plus-side calibration results CLP0, CLP1, CLP2, CLP3, CLP4, and CLPS to
the variable.
3. Divide the variable by two.
4. Set the MSB of the variable.
5. The previous two steps can be achieved by setting the carry bit, rotating to the right
through the carry bit on the high byte and again on the low byte.
6. Store the value in the plus-side gain calibration register PG.
7. Repeat the procedure for the minus-side gain calibration value.
