| 目的:stm32(mini板子)的LED1亮了,则发送一条短信,短信发送成功则LED1灭,结束。不用键盘按键输入电话号码,直接固定电话。 问题:改了原子哥的程序以后,LED1一直亮,短信也就一直不停的发。
 //测试短信发送内容(70个字[UCS2的时候,1个字符/数字都算1个字])
 const u8* sim900a_test_msg="这是一条发送测试短信";
 //SIM900A发短信测试
 void sim900a_sms_send_test(void)
 u8 *p,*p1,*p2;
 //u8 phonebuf[20]; //号码缓存
 //u8 pohnenumlen=0;         //号码长度,最大15个数
 u8* phonenum="15150518392";    //固定电话15150518392
 u8 smssendsta=0;         //短信发送状态,0,等待发送;1,发送失败;2,发送成功
 p=mymalloc(SRAMIN,100);        //申请100个字节的内存,用于存放电话号码的unicode字符串
 p1=mymalloc(SRAMIN,300);//申请300个字节的内存,用于存放短信的unicode字符串
 p2=mymalloc(SRAMIN,100);//申请100个字节的内存 存放:AT+CMGS=p1
 LCD_Clear(WHITE);
 POINT_COLOR=RED;
 Show_Str_Mid(0,30,"ATK-SIM900A 发短信测试",16,240);
 Show_Str(30,50,200,16,"发送给:",16,0);
 Show_Str(30,70,200,16,"状态:",16,0);
 Show_Str(30,90,200,16,"内容:",16,0);
 POINT_COLOR=BLUE;
 Show_Str(30+40,70,170,90,"等待发送",16,0);//显示状态
 Show_Str(30+40,90,170,90,(u8*)sim900a_test_msg,16,0);//显示短信内容
 while(1)
 if(smssendsta)
 smssendsta=0;
 Show_Str(30+40,70,170,90,"正在发送",16,0);//显示正在发送
 //smssendsta=1;
 sim900a_unigbk_exchange((u8*)phonenum,p,1);//将电话号码转换为unicode字符串
 sim900a_unigbk_exchange((u8*)sim900a_test_msg,p1,1);//将短信内容转换为unicode字符串.
 sprintf((char*)p2,"AT+CMGS=\"%s\"",p);
 if(sim900a_send_cmd(p2,">",200)==0)//发送短信命令+电话号码
 u2_printf("%s",p1);        //发送短信内容到GSM模块
 if(sim900a_send_cmd((u8*)0X1A,"+CMGS:",1000)==0)
 smssendsta=2;//发送结束符,等待发送完成(最长等待10秒钟,因为短信长了的话,等待时间会长一些)
 else
 smssendsta=1;
 if(smssendsta==1)
 Show_Str(30+40,70,170,90,"发送失败",16,0);        //显示状态
 else
 Show_Str(30+40,70,170,90,"发送成功",16,0);        //显示状态
 USART2_RX_STA=0;
 LCD_Fill(30+54,50,239,50+16,WHITE);
 Show_Str(30+54,50,156,16,(u8*)phonenum,16,0);
 delay_ms(10);
 if(USART2_RX_STA&0X8000)
 sim_at_response(1);//检查从GSM模块接收到的数据
 myfree(SRAMIN,p);
 myfree(SRAMIN,p1);
 myfree(SRAMIN,p2);
 //sim900a短信测试
 //用于读短信或者发短信
 //返回值:0,正常
 //    其他,错误代码
 u8 sim900a_sms_test(void)
 if(sim900a_send_cmd("AT+CMGF=1","OK",200))return 1;         //设置文本模式
 if(sim900a_send_cmd("AT+CSCS=\"UCS2\"","OK",200))return 2;        //设置TE字符集为UCS2
 if(sim900a_send_cmd("AT+CSMP=17,0,2,25","OK",200))return 3;        //设置短消息文本模式参数
 while(1)
 if(LED1==0)
 sim900a_sms_send_test();  //发短信
 LED1=1;
 //break;
 delay_ms(10);
 sim_at_response(1);         //检查GSM模块发送过来的数据,及时上传给电脑
 sim900a_send_cmd("AT+CSCS=\"GSM\"","OK",200);         //设置默认的GSM 7位缺省字符集
 return 0;
 //sim900a主测试程序
 void sim900a_test(void)
 u8 key=0;
 //        u8 timex=0;
 u8 sim_ready=0;
 POINT_COLOR=RED;
 Show_Str_Mid(0,30,"ATK-SIM900A 测试程序",16,240);
 while(sim900a_send_cmd("AT","OK",100))//检测是否应答AT指令
 Show_Str(40,55,200,16,"未检测到模块!!!",16,0);
 delay_ms(800);
 LCD_Fill(40,55,200,55+16,WHITE);
 Show_Str(40,55,200,16,"尝试连接模块...",16,0);
 delay_ms(400);
 key+=sim900a_send_cmd("ATE0","OK",200);//不回显
 while(1)
 delay_ms(10);
 sim_at_response(1);//检查GSM模块发送过来的数据,及时上传给电脑
 if(sim900a_gsminfo_show(40,225)==0)
 sim_ready=1;
 else
 sim_ready=0;
 if(sim_ready)//SIM卡就绪.
 sim900a_sms_test();
 break;
 //if((timex%20)==0)LED0=!LED0;//200ms闪烁
 //timex++;
