[技术问题解答] imx6qsdp NFS 启动后,无法进入android
2125|1
 楼主| gl4365 发表于 2015-8-4 15:01 | 显示全部楼层 |阅读模式
界面一直卡在android几个字那边,进入不了安卓的桌面而且终端会一直报错
uboot env
setenv ipaddr 10.167.219.172
setenv serverip 10.167.219.113
setenv nfsroot /opt/fsl/root
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200 init=/init root=/dev/nfs rw ip=${ipaddr}:${serverip}:10.167.219.1:255.255.255.0::eth0:off'
setenv bootargs_nfs 'setenv bootargs ${bootargs}  nfsroot=${serverip}:/opt/fsl/root,v3,tcp androidboot.console=ttymxc0 androidboot.hardware=freescale cma=384M'
setenv bootcmd_net 'run bootargs_base bootargs_nfs;bootm'
setenv bootcmd 'tftpboot uImage.fsl; run bootcmd_net'
run bootcmd
上半段log
  1. U-Boot 2009.08-dirty ( 5▒月 27 2014 - 22:32:01)
  2. CPU: Freescale i.MX6 family TO1.2 at 792 MHz
  3. Thermal sensor with ratio = 176
  4. Temperature:   42 C, calibration data 0x55c4b57d
  5. mx6q pll1: 792MHz
  6. mx6q pll2: 528MHz
  7. mx6q pll3: 480MHz
  8. mx6q pll8: 50MHz
  9. ipg clock     : 66000000Hz
  10. ipg per clock : 66000000Hz
  11. uart clock    : 80000000Hz
  12. cspi clock    : 60000000Hz
  13. ahb clock     : 132000000Hz
  14. axi clock   : 264000000Hz
  15. emi_slow clock: 132000000Hz
  16. ddr clock     : 528000000Hz
  17. usdhc1 clock  : 198000000Hz
  18. usdhc2 clock  : 198000000Hz
  19. usdhc3 clock  : 198000000Hz
  20. usdhc4 clock  : 198000000Hz
  21. nfc clock     : 24000000Hz
  22. Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
  23. Boot Device: MMC
  24. I2C:   ready
  25. DRAM:   1 GB
  26. MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
  27. *** Warning - bad CRC or MMC, using default environment
  28. In:    serial
  29. Out:   serial
  30. Err:   serial
  31. Found PFUZE100! deviceid=10,revid=11
  32. Net:   got MAC address from IIM: 00:04:9f:02:e4:c1
  33. FEC0 [PRIME]
  34. Hit any key to stop autoboot:  0
  35. MX6Q SABRESD U-Boot >
  36. MX6Q SABRESD U-Boot >
  37. MX6Q SABRESD U-Boot >
  38. MX6Q SABRESD U-Boot >
  39. MX6Q SABRESD U-Boot > setenv ipaddr 10.167.219.172
  40. MX6Q SABRESD U-Boot > setenv serverip 10.167.219.113
  41. MX6Q SABRESD U-Boot > setenv nfsroot /opt/fsl/root
  42. MX6Q SABRESD U-Boot > setenv bootargs_base 'setenv bootargs console=ttymxc0,1152
  43. 00 init=/init root=/dev/nfs rw ip=${ipaddr}:${serverip}:10.167.219.1:255.255.255
  44. .0::eth0:off'
  45. MX6Q SABRESD U-Boot > setenv bootargs_nfs 'setenv bootargs ${bootargs}  nfsroot=
  46. ${serverip}:/opt/fsl/root,v3,tcp androidboot.console=ttymxc0 androidboot.hardwar
  47. e=freescale cma=384M'
  48. MX6Q SABRESD U-Boot > setenv bootcmd_net 'run bootargs_base bootargs_nfs;bootm'
  49. MX6Q SABRESD U-Boot > setenv bootcmd 'tftpboot uImage.fsl; run bootcmd_net'
  50. MX6Q SABRESD U-Boot > run bootcmd
  51. PHY indentify [url=home.php?mod=space&uid=72445]@[/url] 0x1 = 0x004dd074
  52. FEC: Link is Up 796d
  53. Using FEC0 device
  54. TFTP from server 10.167.219.113; our IP address is 10.167.219.172
  55. Filename 'uImage.fsl'.
  56. Load address: 0x10800000
  57. Loading: #################################################################
  58.          #################################################################
  59.          #################################################################
  60.          #################################################################
  61.          #################################################################
  62.          #####
  63. done
  64. Bytes transferred = 4841328 (49df70 hex)
  65. ## Booting kernel from Legacy Image at 10800000 ...
  66.    Image Name:   Linux-3.0.35-06522-g0a3529b-dirt
  67.    Image Type:   ARM Linux Kernel Image (uncompressed)
  68.    Data Size:    4841264 Bytes =  4.6 MB
  69.    Load Address: 10008000
  70.    Entry Point:  10008000
  71.    Verifying Checksum ... OK
  72.    Loading Kernel Image ... OK
  73. OK
  74. Starting kernel ...
  75. Uncompressing Linux... done, booting the kernel.
  76. Initializing cgroup subsys cpu
  77. Linux version 3.0.35-06522-g0a3529b-dirty () (gcc version 4.6.
  78. x-google 20120106 (prerelease) (GCC) ) #33 SMP PREEMPT Thu Jan 29 08:44:49 CST 2
  79. 015
  80. CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
  81. CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
  82. Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
  83. Ignoring unrecognised tag 0x54410008
  84. Memory policy: ECC disabled, Data cache writealloc
  85. CPU identified as i.MX6Q, silicon rev 1.2
  86. PERCPU: Embedded 7 pages/cpu @c133c000 s6528 r8192 d13952 u32768
  87. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 210688
  88. Kernel command line: console=ttymxc0,115200 init=/init root=/dev/nfs rw ip=10.16
  89. 7.219.172:10.167.219.113:10.167.219.1:255.255.255.0::eth0:off nfsroot=10.167.219
  90. .113:/opt/fsl/root,v3,tcp androidboot.console=ttymxc0 androidboot.hardware=frees
  91. cale cma=384M
  92. PID hash table entries: 4096 (order: 2, 16384 bytes)
  93. Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
  94. Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
  95. Memory: 767MB 64MB = 831MB total
  96. Memory: 830332k/830332k available, 218244k reserved, 162816K highmem
  97. Virtual kernel memory layout:
  98.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  99.     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
  100.     DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
  101.     vmalloc : 0xea800000 - 0xf2000000   ( 120 MB)
  102.     lowmem  : 0xc0000000 - 0xea000000   ( 672 MB)
  103.     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
  104.     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
  105.       .init : 0xc0008000 - 0xc0047000   ( 252 kB)
  106.       .text : 0xc0047000 - 0xc090f538   (8994 kB)
  107.       .data : 0xc0910000 - 0xc09aa358   ( 617 kB)
  108.        .bss : 0xc09aa37c - 0xc0b32e9c   (1571 kB)
  109. Preemptible hierarchical RCU implementation.
  110. NR_IRQS:624
  111. MXC GPIO hardware
  112. sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
  113. arm_max_freq=1GHz
  114. MXC_Early serial console at MMIO 0x2020000 (options '115200')
  115. bootconsole [ttymxc0] enabled
  116. Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
  117. pid_max: default: 32768 minimum: 301
  118. Security Framework initialized
  119. SELinux:  Initializing.
  120. Mount-cache hash table entries: 512
  121. Initializing cgroup subsys debug
  122. Initializing cgroup subsys cpuacct
  123. Initializing cgroup subsys freezer
  124. CPU: Testing write buffer coherency: ok
  125. hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
  126. CPU1: Booted secondary processor
  127. CPU2: Booted secondary processor
  128. CPU3: Booted secondary processor
  129. Brought up 4 CPUs
  130. SMP: Total of 4 processors activated (6324.22 BogoMIPS).
  131. print_constraints: dummy:
  132. NET: Registered protocol family 16
  133. print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
  134. print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
  135. print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
  136. print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
  137. print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
  138. print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
  139. ram_console: got buffer at 3ff00000, size 100000
  140. ram_console: found existing buffer, size 104001, start 104001
  141. console [ram-1] enabled
  142. No AHCI save PWR: PDDQ enabled
  143. hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
  144. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
  145. hw-breakpoint: maximum watchpoint size is 4 bytes.
  146. L310 cache controller enabled
  147. l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
  148. bio: create slab <bio-0> at 0
  149. mxs-dma mxs-dma-apbh: initialized
  150. print_constraints: SPKVDD: 4200 mV
  151. print_constraints: vmmc: 3300 mV
  152. vgaarb: loaded
  153. SCSI subsystem initialized
  154. spi_imx imx6q-ecspi.0: probed
  155. usbcore: registered new interface driver usbfs
  156. usbcore: registered new interface driver hub
  157. usbcore: registered new device driver usb
  158. Freescale USB OTG Driver loaded, $Revision: 1.55 $
  159. mc_pfuze 1-0008: ID: 0,Full lay: 1 ,Metal lay: 1
  160. mc_pfuze 1-0008: FAB: 0 ,FIN: 0
  161. print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
  162. print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
  163. print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
  164. print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
  165. print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
  166. print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
  167. print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
  168. print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
  169. print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
  170. print_constraints: PFUZE100_VREFDDR: at 750 mV
  171. print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
  172. print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
  173. print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
  174. print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
  175. print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
  176. print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
 楼主| gl4365 发表于 2015-8-4 15:02 | 显示全部楼层
另一段log
  1. imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  2. imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  3. mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
  4. mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
  5. MIPI CSI2 driver module loaded
  6. Advanced Linux Sound Architecture Driver Version 1.0.24.
  7. Bluetooth: Core ver 2.16
  8. NET: Registered protocol family 31
  9. Bluetooth: HCI device and connection manager initialized
  10. Bluetooth: HCI socket layer initialized
  11. Bluetooth: L2CAP socket layer initialized
  12. Bluetooth: SCO socket layer initialized
  13. max17135_regulator_init abort: EPDC not enabled
  14. max17135 2-0048: PMIC MAX17135 for eInk display
  15. i2c-core: driver [max17135] using legacy suspend method
  16. i2c-core: driver [max17135] using legacy resume method
  17. Switching to clocksource mxc_timer1
  18. NET: Registered protocol family 2
  19. IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
  20. TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
  21. TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
  22. TCP: Hash tables configured (established 131072 bind 65536)
  23. TCP reno registered
  24. UDP hash table entries: 512 (order: 2, 16384 bytes)
  25. UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  26. NET: Registered protocol family 1
  27. RPC: Registered named UNIX socket transport module.
  28. RPC: Registered udp transport module.
  29. RPC: Registered tcp transport module.
  30. RPC: Registered tcp NFSv4.1 backchannel transport module.
  31. PCI: CLS 0 bytes, default 32
  32. PMU: registered new PMU device of type 0
  33. Static Power Management for Freescale i.MX6
  34. wait mode is enabled for i.MX6
  35. cpaddr = ea880000 suspend_iram_base=ea92c000
  36. PM driver module loaded
  37. iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
  38. PCIE: imx_pcie_pltfm_probe start link up.
  39. link up failed, DB_R0:0x005ebd00, DB_R1:0x08200000!
  40. IMX PCIe port: link down with power supply 1!
  41. IMX usb wakeup probe
  42. the wakeup pdata is 0xe66f5ba0
  43. add wake up source irq 75
  44. IMX usb wakeup probe
  45. the wakeup pdata is 0xe66f5920
  46. cpu regulator mode:ldo_bypass
  47. _regulator_get: get() with no identifier
  48. mx6_cpu_regulator_init: failed to get pu regulator
  49. i.MXC CPU frequency driver
  50. audit: initializing netlink socket (disabled)
  51. type=2000 audit(2.080:1): initialized
  52. highmem bounce pool size: 64 pages
  53. ashmem: initialized
  54. NTFS driver 2.1.30 [Flags: R/O].
  55. JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
  56. fuse init (API version 7.16)
  57. msgmni has been set to 1303
  58. SELinux:  Registering netfilter hooks
  59. NET: Registered protocol family 38
  60. cryptodev: driver loaded.
  61. io scheduler noop registered
  62. io scheduler deadline registered
  63. io scheduler cfq registered (default)
  64. mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
  65. MIPI DSI driver module loaded
  66. mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
  67. _regulator_get: get() with no identifier
  68. imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
  69. mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver hdmi
  70. mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
  71. fbcvt: 1920x1080@60: CVT Name - 2.073M9
  72. mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
  73. imx-sdma imx-sdma: loaded firmware 1.1
  74. imx-sdma imx-sdma: initialized
  75. Serial: IMX driver
  76. imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
  77. imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
  78. console [ttymxc0] enabled, bootconsole disabled
  79. console [ttymxc0] enabled, bootconsole disabled
  80. loop: module loaded
  81. m25p80 spi0.0: found m25p32, expected sst25vf016b
  82. m25p80 spi0.0: m25p32 (4096 Kbytes)
  83. Creating 2 MTD partitions on "m25p80":
  84. 0x000000000000-0x000000100000 : "bootloader"
  85. 0x000000100000-0x000000400000 : "kernel"
  86. GPMI NAND driver registered. (IMX)
  87. vcan: Virtual CAN interface driver
  88. CAN device driver interface
  89. flexcan netdevice driver
  90. FEC Ethernet Driver
  91. fec_enet_mii_bus: probed
  92. PPP generic driver version 2.4.2
  93. PPP Deflate Compression module registered
  94. PPP BSD Compression module registered
  95. PPP MPPE Compression module registered
  96. NET: Registered protocol family 24
  97. tun: Universal TUN/TAP device driver, 1.6
  98. tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  99. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  100. fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
  101. fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
  102. fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
  103. fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
  104. hub 1-0:1.0: USB hub found
  105. hub 1-0:1.0: 1 port detected
  106. add wake up source irq 72
  107. fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
  108. fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
  109. fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
  110. fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
  111. hub 2-0:1.0: USB hub found
  112. hub 2-0:1.0: 1 port detected
  113. usbcore: registered new interface driver cdc_acm
  114. cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
  115. Initializing USB Mass Storage driver...
  116. usbcore: registered new interface driver usb-storage
  117. USB Mass Storage support registered.
  118. usbcore: registered new interface driver usbserial
  119. usbserial: USB Serial Driver core
  120. USB Serial support registered for GSM modem (1-port)
  121. usbcore: registered new interface driver option
  122. option: v0.7.2:USB Driver for GSM modems
  123. USB Serial support registered for Qualcomm USB modem
  124. usbcore: registered new interface driver qcserial
  125. ARC USBOTG Device Controller driver (1 August 2005)
  126. android_usb gadget: Mass Storage Function, version: 2009/09/11
  127. android_usb gadget: Number of LUNs=1
  128. lun0: LUN: removable file: (no medium)
  129. Gadget Android: controller 'fsl-usb2-udc' not recognized
  130. android_usb gadget: android_usb ready
  131. Suspend udc for OTG auto detect
  132. USB Host suspend begins
  133. will suspend roothub and its children
  134. ehci_fsl_bus_suspend begins, DR
  135. ehci_fsl_bus_suspend ends, DR
  136. host suspend ends
  137. USB Gadget resume begins
  138. fsl_udc_resume, Wait for wakeup thread finishes
  139. dr_controller_run: udc enter low power mode
  140. USB Gadget resume ends
  141. fsl-usb2-udc: bind to driver android_usb
  142. mousedev: PS/2 mouse device common for all mice
  143. input: gpio-keys as /devices/platform/gpio-keys/input/input0
  144. input: max11801_ts as /devices/platform/imx-i2c.1/i2c-1/1-0048/input/input1
  145. egalax_ts 1-0004: egalax_ts: failed to read firmware version
  146. egalax_ts: probe of 1-0004 failed with error -5
  147. input: eGalax Touch Screen as /devices/platform/imx-i2c.2/i2c-2/2-0004/input/inp
  148. ut2
  149. elan - Read Hello Packet Failed
  150. elan-touch: probe of 2-0010 failed with error -22
  151. input: isl29023 light sensor as /devices/virtual/input/input3
  152. isl29023 2-0044: driver version 1.0 enabled
  153. i2c-core: driver [isl29023] using legacy suspend method
  154. i2c-core: driver [isl29023] using legacy resume method
  155. using rtc device, snvs_rtc, for alarms
  156. snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
  157. i2c /dev entries driver
  158. Linux video capture interface: v2.00
  159. ov5642_read_reg:write reg error:reg=300a
  160. camera ov5642 is not found
  161. USB Gadget resume begins
  162. fsl_udc_resume, Wait for wakeup thread finishes
  163. ov5640_read_reg:write reg error:reg=300a
  164. camera ov5640 is not found
  165. ov5640_read_reg:write reg error:reg=300a
  166. camera ov5640_mipi is not found
  167. mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
  168. mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
  169. mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
  170. mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
  171. mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
  172. usbcore: registered new interface driver uvcvideo
  173. USB Video Class driver (v1.1.0)
  174. mag3110 2-000e: check mag3110 chip ID
  175. input: FreescaleMagnetometer as /devices/virtual/input/input4
  176. input: eCompass as /devices/virtual/input/input5
  177. mag3110 2-000e: mag3110 is probed
  178. i2c-core: driver [mag3110] using legacy suspend method
  179. i2c-core: driver [mag3110] using legacy resume method
  180. input: FreescaleAccelerometer as /devices/virtual/input/input6
  181. mma8x5x device driver probe successfully
  182. imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
  183. device-mapper: uevent: version 1.0.3
  184. device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
  185. Bluetooth: Virtual HCI driver ver 1.3
  186. Bluetooth: HCI UART driver ver 2.2
  187. Bluetooth: HCIATH3K protocol initialized
  188. Bluetooth: Generic Bluetooth USB driver ver 0.6
  189. usbcore: registered new interface driver btusb
  190. sdhci: Secure Digital Host Controller Interface driver
  191. sdhci: Copyright(c) Pierre Ossman
  192. mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
  193. mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
  194. mmc2: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
  195. mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
  196. VPU initialized
  197. mxc_asrc registered
  198. Galcore version 4.6.9.9754
  199. Thermal calibration data is 0x55c4b57d
  200. Thermal sensor with ratio = 176
  201. Anatop Thermal registered as thermal_zone0
  202. anatop_thermal_probe: default cooling device is cpufreq!
  203. Registered led device: chg_now_led
  204. usbcore: registered new interface driver usbhid
  205. usbhid: USB HID core driver
  206. logger: created 256K log 'log_main'
  207. logger: created 256K log 'log_events'
  208. logger: created 256K log 'log_radio'
  209. logger: created 256K log 'log_system'
  210. usbcore: registered new interface driver snd-usb-audio
  211. mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
  212. Cirrus Logic CS42888 ALSA SoC Codec Driver
  213. i2c-core: driver [cs42888] using legacy suspend method
  214. i2c-core: driver [cs42888] using legacy resume method
  215. mmc0: new high speed DDR MMC card at address 0001
  216. mmcblk0: mmc0:0001 SEM08G 7.39 GiB
  217. mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
  218. mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
  219. mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
  220. mmcblk0: p4 size 13336576 extends beyond EOD, truncated
  221. mmcblk0boot1: unknown partition table
  222. mmcblk0boot0: unknown partition table
  223. wm8962 0-001a: customer id 0 revision D
  224. input: WM8962 Beep Generator as /devices/platform/imx-i2c.0/i2c-0/0-001a/input/i
  225. nput7
  226. asoc: wm8962 <-> imx-ssi.1 mapping ok
  227. input: wm8962-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input8
  228. input: wm8962-audio Headphone Jack as /devices/platform/soc-audio.5/sound/card0/
  229. input9
  230. imx_3stack asoc driver
  231. asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
  232. ALSA device list:
  233.   #0: wm8962-audio
  234.   #1: imx-hdmi-soc
  235. oprofile: using arm/armv7-ca9
  236. u32 classifier
  237.     Actions configured
  238. Netfilter messages via NETLINK v0.30.
  239. nf_conntrack version 0.5.0 (12973 buckets, 51892 max)
  240. ctnetlink v0.93: registering with nfnetlink.
  241. NF_TPROXY: Transparent proxy support initialized, version 4.1.0
  242. NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
  243. xt_time: kernel timezone is -0000
  244. ip_tables: (C) 2000-2006 Netfilter Core Team
  245. arp_tables: (C) 2002 David S. Miller
  246. TCP cubic registered
  247. Initializing XFRM netlink socket
  248. NET: Registered protocol family 10
  249. Mobile IPv6
  250. ip6_tables: (C) 2000-2006 Netfilter Core Team
  251. NET: Registered protocol family 17
  252. NET: Registered protocol family 15
  253. can: controller area network core (rev 20090105 abi 8)
  254. NET: Registered protocol family 29
  255. can: raw protocol (rev 20090105)
  256. can: broadcast manager protocol (rev 20090105 t)
  257. Bluetooth: RFCOMM TTY layer initialized
  258. Bluetooth: RFCOMM socket layer initialized
  259. Bluetooth: RFCOMM ver 1.11
  260. Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  261. Bluetooth: BNEP filters: protocol multicast
  262. Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  263. lib80211: common routines for IEEE802.11 drivers
  264. lib80211_crypt: registered algorithm 'NULL'
  265. lib80211_crypt: registered algorithm 'WEP'
  266. lib80211_crypt: registered algorithm 'CCMP'
  267. lib80211_crypt: registered algorithm 'TKIP'
  268. VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
  269. Bus freq driver module loaded
  270. Bus freq driver Enabled
  271. mxc_dvfs_core_probe
  272. DVFS driver module loaded
  273. regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
  274. regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
  275. regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
  276. regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
  277. snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 01:17:20 UTC (91040)
  278. eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
  279. ADDRCONF(NETDEV_UP): eth0: link is not ready
  280. ehci_fsl_bus_suspend begins, Host 1
  281. ehci_fsl_bus_suspend ends, Host 1
  282. PHY: 1:01 - Link is Up - 100/Full
  283. ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  284. IP-Config: Complete:
  285.      device=eth0, addr=10.167.219.172, mask=255.255.255.0, gw=10.167.219.1,
  286.      host=10.167.219.172, domain=, nis-domain=(none),
  287.      bootserver=10.167.219.113, rootserver=10.167.219.113, rootpath=
  288. VFS: Mounted root (nfs filesystem) on device 0:13.
  289. Freeing init memory: 252K
  290. pid=2343 comm="init" path="/sbin/healthd" dev=0:d ino=14163383 scontext=u:r:hea
  291. lthd:s0 tcontext=u:object_r:rootfs:s0 tclass=file
  292. init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
  293. healthd: wakealarm_init: timerfd_create failed
  294. healthd: BatteryTemperaturePath not found
  295. healthd: BatteryTechnologyPath not found
  296. binder: 2343:2343 transaction failed 29189, size 0-0
  297. SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
  298. cfg80211: disagrees about version of symbol wireless_send_event
  299. cfg80211: Unknown symbol wireless_send_event (err -22)
  300. cfg80211: disagrees about version of symbol malloc_sizes
  301. cfg80211: Unknown symbol malloc_sizes (err -22)
  302. root@sabresd_6dq:/ # init: using deprecated syntax for specifying property 'ro.s
  303. erialno', use ${name} instead
  304. init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno'
  305. init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/andr
  306. oid0/iSerial'
  307. init: using deprecated syntax for specifying property 'ro.product.manufacturer',
  308. use ${name} instead
  309. init: using deprecated syntax for specifying property 'ro.product.model', use ${
  310. name} instead
  311. init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
  312. init: powerctl: cannot expand '${sys.powerctl}'
  313. init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${s
  314. ys.sysctl.extra_free_kbytes}'
  315. init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sy
  316. s/vm/extra_free_kbytes'
  317. android_usb: already disabled
  318. mtp_bind_config
  319. adb_bind_config
  320. adb_open
  321. ERROR: v4l2 capture: slave not found!
  322. ERROR: v4l2 capture: slave not found!
  323. ERROR: v4l2 capture: slave not found!
  324. ERROR: v4l2 capture: slave not found!
  325. ERROR: v4l2 capture: slave not found!
  326. ERROR: v4l2 capture: slave not found!
  327. ERROR: v4l2 capture: slave not found!
  328. ERROR: v4l2 capture: slave not found!
  329. ERROR: HDMI is not ready!
  330. asoc: can't open platform imx-hdmi-soc-audio.0
  331. SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
  332. eth0: no IPv6 routers present
  333. warning: `zygote' uses 32-bit capabilities (legacy support in use)
  334. type=1400 audit(91056.630:5): avc:  denied  { write } for  pid=2696 comm="system
  335. _server" name="property_service" dev=tmpfs ino=5445 scontext=u:r:zygote:s0 tcont
  336. ext=u:object_r:property_socket:s0 tclass=sock_file
  337. request_suspend_state: wakeup (3->0) at 20900478004 (1970-01-02 01:17:36.7805473
  338. 35 UTC)
  339. type=1400 audit(91056.790:6): avc:  denied  { read write } for  pid=2710 comm="a
  340. pp_process" path="socket:[3251]" dev=sockfs ino=3251 scontext=u:r:zygote:s0 tcon
  341. text=u:r:init:s0 tclass=unix_stream_socket
  342. type=1400 audit(91056.790:7): avc:  denied  { read write } for  pid=2709 comm="n
  343. etd" path="socket:[5614]" dev=sockfs ino=5614 scontext=u:r:netd:s0 tcontext=u:r:
  344. init:s0 tclass=unix_stream_socket
  345. type=1400 audit(91056.790:8): avc:  denied  { read write } for  pid=2709 comm="n
  346. etd" path="socket:[5617]" dev=sockfs ino=5617 scontext=u:r:netd:s0 tcontext=u:r:
  347. init:s0 tclass=unix_stream_socket
  348. type=1400 audit(91056.790:9): avc:  denied  { read write } for  pid=2709 comm="n
  349. etd" path="socket:[5619]" dev=sockfs ino=5619 scontext=u:r:netd:s0 tcontext=u:r:
  350. init:s0 tclass=unix_stream_socket
  351. ERROR: v4l2 capture: slave not found!
  352. ERROR: v4l2 capture: slave not found!
  353. ERROR: v4l2 capture: slave not found!
  354. ERROR: v4l2 capture: slave not found!
  355. ERROR: v4l2 capture: slave not found!
  356. ERROR: v4l2 capture: slave not found!
  357. ERROR: v4l2 capture: slave not found!
  358. ERROR: v4l2 capture: slave not found!
  359. ERROR: HDMI is not ready!
  360. asoc: can't open platform imx-hdmi-soc-audio.0
  361. SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
  362. request_suspend_state: wakeup (0->0) at 21990539004 (1970-01-02 01:17:37.8706090
  363. 01 UTC)
  364. init: untracked pid 2932 exited
