[ZLG-MCU] LPC1766+DM9161AEP 网络问题
1258|0
 楼主| hxm4148 发表于 2015-9-2 13:57 | 显示全部楼层 |阅读模式
使用周立公初始化为自适应100M经常丢包,连接不稳定,看网上说强制10M比较稳定,请问一下,初始化需要如何设置成强制10M? 原来的初始化
void InitNic(INT8U num)
    static INT8U bINT = 0;
        INT32U i;
        PCONP |= 0X40000000;
    /* Set the PIN to RMII */
   // PINSEL2 &= 0x0fc0ccf0;
    //PINSEL2 |= 0X50151105; //PINSEL2 = 0x50151105;        /* selects P1[0,1,4,8,9,10,14,15] */
    //PINSEL3 &= 0xfffffff0;
    //PINSEL3 |= 0X00000005; //PINSEL3 = 0x00000005;        /* selects P1[17:16] */
    //i = rMAC_MODULEID;
    //if(i == OLD_EMAC_MODULE_ID)
    //        PINSEL2 = 0x50151105;        /* selects P1[0,1,4,8,9,10,14,15] */
    //else
    //        PINSEL2 = 0x50150105;
    //old
    PINSEL2 |= (1)|(1<<2)|(1<<8)|(1<<16)|(1<<18)|(1<<20)|(1<<28)|(1<<30);  /* selects P1[0,1,4,8,9,10,14,15] */
    //new
    //PINSEL2 = 0x50150105;
    PINSEL3 |= 0x00000005;        /* selects P1[17:16] */
    /* reset : soft,simulation,mcs/rx,rx,mcs/tx,tx */
    MAC_MAC1 = 0xCF00;        /* [15],[14],[11:8] -> soft resets all MAC internal modules */
    /* RegReset,TxReset,RxReset */
    MAC_COMMAND = 0x0038;        /* reset all datapaths and host registers */
    OSTimeDly(20);
    //for ( i = 0; i < 0x64; i++ );        /* short delay after reset */
    MAC_MAC1 = 0x0;                /* deassert all of the above soft resets in MAC1 */
    EMAC_TxDisable();
    EMAC_RxDisable();
    MAC_MAC2 = 0x00;                /* initialize MAC2 register to default value */
    /* Non back to back inter-packet gap */
    MAC_IPGR = 0x0012;        /* use the default value recommended in the users manual */
    MAC_CLRT = 0x370F;        /* Use the default value in the users manual */
    MAC_MAXF = 0x0600;        /* Use the default value in the users manual */
    /* PHY Select RMII */
    ///rECOMMAND |= (1<<9);
    /* Initial MII Mgmt */
    // rMCFG |= (7<<2) + 1;                   //clk div 28,address increment
    //MAC_MCFG = 0x801d;
    //MAC_MCFG |= 0x0019;        /* host clock divided by 20, no suppress preamble, no scan increment */
    MAC_MCFG |= 0x0018;
    /* RMII configuration */
    //MAC_COMMAND |= 0x0200;
    MAC_COMMAND = 0x0240;
    //MAC_SUPP = 0x0900;        /* hxm RMII setting, PHY support: [8]=0 ->10 Mbps mode, =1 -> 100 Mbps mode */
    /*  (note bit 4 was set in original test, although spec says its unused) */
    //for ( i = 0; i < 0x64; i++ );        /* short delay */
    OSTimeDly(20);
    //MAC_SUPP = 0x0100;
           MAC_SUPP = 0x0000;
   // probe phy address
        for(i=0;i<32;i++)
            PHYID = Read_PHY(i , 2 );
            if(PHYID == 0X0181)
                    break;
        OSTimeDly(1);
    if(i >= 32){
        OSTimeDly(OS_TICKS_PER_SEC*3);
            return;
    PHYID = i;
    /// PHY RESET
    Write_PHY(PHYID, 0, 0x9200 );
        //Write_PHY( 0, 0x0000 );
    //old 2012-09-18 wsht
    OSTimeDly(OS_TICKS_PER_SEC * 16);
    for(i=0;i<32;i++)
            PHYREG[i] = Read_PHY(PHYID ,i );
    tempreg = Read_PHY(PHYID, 17 );
    /* INPUT MAC ADDRESS */
    SetMacID(NetPort[num].My_Mac);
    if(tempreg & 0x8000)//100fdx
            dulxp = 1;
            speed = 100; //100
            MAC_MAC2 = 0x31;                /* half duplex, CRC and PAD enabled. */
                MAC_SUPP |= 0x0100;//0x0100                /* RMII Support Reg. speed is set to 100M */
                MAC_COMMAND |= 0x0640;
                /* back to back int-packet gap */
                MAC_IPGT = 0x0015;                /* IPG setting in half duplex mode */
    else if(tempreg & 0x4000)//100hdx
            dulxp = 0;
            speed = 100;  //100
            MAC_MAC2 = 0x30;                /* full duplex, CRC and PAD enabled. */
                MAC_SUPP |= 0x0100;        //0x0100        /* RMII Support Reg. speed is set to 100M */
                MAC_COMMAND |= 0x0240;
                MAC_IPGT = 0x0012;        /* IPG setting in full duplex mode */
    else if(tempreg & 0x2000)//10fdx
            dulxp = 1;
            speed = 10;
            MAC_MAC2 = 0x31;                /* full duplex, CRC and PAD enabled. */
                MAC_SUPP = 0;        /* RMII Support Reg. speed is set to 10M */
                MAC_IPGT = 0x0015;                /* IPG setting in full duplex mode */
    else if(tempreg & 0x1000)//10hdx
            dulxp = 0;
            speed = 10;
            MAC_MAC2 = 0x30;                /* half duplex, CRC and PAD enabled. */
                MAC_IPGT = 0x0012;                /* IPG setting in half duplex mode */
    EMACTxDescriptorInit();
    EMACRxDescriptorInit();
    MAC_MAC1 |= 0x0002;                /* [1]-Pass All Rx Frame */
    /* Set up RX filter, accept broadcast and perfect station */
    MAC_RXFILTERCTRL = 0x0022;        /* [1]-accept broadcast, [5]accept perfect */
        MAC_RXFILTERCTRL |= 0x0005;//MULTICAST_UNICAST
    MAC_RXFILTERCTRL |= 0x0018;//ENABLE_HASH
    /* MAC interrupt related register setting */
    //if ( install_irq( EMAC_INT, (void *)EMACHandler, HIGHEST_PRIORITY ) == FALSE )
        //        return (FALSE);
    //MAC_INTENABLE = 0x00FF;        /* Enable all interrupts except SOFTINT and WOL */
        EMAC_RxEnable();
    EMAC_TxEnable();
    LINKSTATUS = 1;
    MAC_INTENABLE = 0x000c;        /* Enable all interrupts except SOFTINT and WOL */
    MAC_INTCLEAR = 0xFF;        /* clear all MAC interrupts */
    EINTSTA = 0;
    if (bINT == 0){
        zyIsrSet (NVIC_ETHR, (unsigned long)Ethernet_Exception, PRIO_FOUR);
        bINT = 1;
   // MAC_INTENABLE = 0x000c;        /* Enable all interrupts except SOFTINT and WOL */
