晕了,香主帮帮忙啊
2088|1
 楼主| 古道122 发表于 2008-8-14 19:51 | 显示全部楼层 |阅读模式
AD, ADC, dc, ADC1, ST
我想对三路数据进行AD转换,不用同时的,但是这样写的为什么转换的老是设定的第一个Channel的数据呢?数组abc里总是保存的第一个channel的数据
 /* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//
ADC_InitStructure.ADC_ScanConvMode = DISABLE;//
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//
ADC_InitStructure.ADC_NbrOfChannel = 3;//
ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channel10 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 3, ADC_SampleTime_55Cycles5);
 /* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);//
 /* Enable ADC1 reset calibaration register */
ADC_ResetCalibration(ADC1);
/* Check the end of ADC1 reset calibration register *//
while(ADC_GetResetCalibrationStatus(ADC1));
 /* Start ADC1 calibaration */
ADC_StartCalibration(ADC1);
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion *//
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
#if 1
while(1)
while(!(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)));
value = (ADC1->DR);
 abc[own] = value;
 own++;
 if(own == 3)
 ADC_Cmd(ADC1,DISABLE);
 楼主| 古道122 发表于 2008-8-14 20:32 | 显示全部楼层
看了一下
0x40012400地址的数据总是0x00000012,即开启转换,并且标志EOC在读取AD值之后也并没有变成0。就算是手动设置也没有效果。- -!
