[FPGA] [求助]Spartan-6可以通过JTAG识别,但是却下载不了程序!!!
3599|3
 楼主| gaolou1991 发表于 2015-9-27 10:13 | 显示全部楼层 |阅读模式
使用的SPI的x4模式,配置电路如下图所示:
下载的时候出现的信息如下:
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2015/9/24 12:57:17
PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx45, Version : 4
INFO:iMPACT:1777 -
Reading C:/Xilinx/14.7/ISE_DS/ISE/spartan6/data/xc6slx45.bsd...
INFO:iMPACT:501 - '1': Added Device xc6slx45 successfully.
done.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
'1': Loading file 'D:/Project/Xilinx/ad_da_test/lrd_lest.bit' ...
done.
INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
UserID read from the bitstream file = 0xFFFFFFFF.
Data width read from the bitstream file = 1.
INFO:iMPACT - Current time: 2015/9/24 12:57:45
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] IDCODE ERROR                                                           :         0
[2] DCM LOCK STATUS                                                        :         0
[3] GTS_CFG_B STATUS                                                       :         0
[4] GWE STATUS                                                             :         0
[5] GHIGH STATUS                                                           :         0
[6] DECRYPTION ERROR                                                       :         0
[7] DECRYPTOR ENABLE                                                       :         0
[8] HSWAPEN PIN                                                            :         0
[9] MODE PIN M[0]                                                          :         0
[10] MODE PIN M[1]                                                         :         0
[11] RESERVED                                                              :         0
[12] INIT_B PIN                                                            :         0
[13] DONE PIN                                                              :         0
[14] SUSPEND STATUS                                                        :         0
[15] FALLBACK STATUS                                                       :         0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
'1': Programming terminated. DONE did not go high.
Elapsed time =      3 sec.
求大神帮帮忙。。。感觉电路没有错误啊!!!使用USB可以下载其他的芯片!!!USB应该没有问题。
yizi0000 发表于 2015-10-7 21:03 | 显示全部楼层
启动模式M2/1/0设置的是SPI模式吗,ISE的信息说bit文件下载进去了,但是DONE没有拉高。
yangfenyan 发表于 2016-2-15 15:30 | 显示全部楼层
碰到同样的问题。你怎么解决的?多谢
fhpzxq 发表于 2016-2-24 22:46 | 显示全部楼层
MODE管脚的配置有问题会出现这个错误,SPARTAN6的MODE腿上拉或者下拉电阻改为0欧姆试试,可以参考链接评估一下https://item.taobao.com/item.htm?id=527190762240
