这个就是从我推荐的那篇**中抽出来的呀~~~~
9452|11
 楼主| mygaojian 发表于 2008-6-16 16:59 | 显示全部楼层 |阅读模式
下图是AD公司的介绍资料中的图
说明
The name "DGND" on an IC tells us that this pin connects to the digital ground of the IC.
This does not imply that this pin must be connected to the digital ground of the system.
It is true that this arrangement may inject a small amount of digital noise onto the analog
ground plane. These currents should be quite small, and can be minimized by ensuring
that the converter output does not drive a large fanout (they normally can't, by design).
Minimizing the fanout on the converter's digital port will also keep the converter logic
transitions relatively free from ringing and minimize digital switching currents, and
thereby reducing any potential coupling into the analog port of the converter. The logic
supply pin (VD) can be further isolated from the analog supply by the insertion of a small
lossy ferrite bead as shown in Figure 9.26. The internal transient digital currents of the
converter will flow in the small loop from VD through the decoupling capacitor and to
DGND (this path is shown with a heavy line on the diagram). The transient digital
currents will therefore not appear on the external analog ground plane, but are confined to
the loop. The VD pin decoupling capacitor should be mounted as close to the converter as
possible to minimize parasitic inductance. These decoupling capacitors should be low
inductance ceramic types, typically between 0.01 μF and 0.1 μF.
 楼主| mygaojian 发表于 2008-6-16 17:02 | 显示全部楼层
想看的看下,不堪
Inside an IC that has both analog and digital circuits, such as an ADC or a DAC, the
grounds are usually kept separate to avoid coupling digital signals into the analog
circuits. Figure 9.26 shows a simple model of a converter. There is nothing the IC
designer can do about the wirebond inductance and resistance associated with connecting
the bond pads on the chip to the package pins except to realize it's there. The rapidly
changing digital currents produce a voltage at point B which will inevitably couple into
point A of the analog circuits through the stray capacitance, CSTRAY. In addition, there
is approximately 0.2-pF unavoidable stray capacitance between every pin of the IC
package! It's the IC designer's job to make the chip work in spite of this. However, in
order to prevent further coupling, the AGND and DGND pins should be joined together externally to the analog ground plane with minimum lead lengths. Any extra impedance
in the DGND connection will cause more digital noise to be developed at point B; it will,
in turn, couple more digital noise into the analog circuit through the stray capacitance.
Note that connecting DGND to the digital ground plane applies VNOISE across the
AGND and DGND pins and invites disaster!
zjp8683463 发表于 2008-6-17 10:05 | 显示全部楼层
不连一起直接烧ADC
不练一起就相当于2个隔离电源,2个地之间有地差,那么就会超ADC的共模范围
computer00 发表于 2008-6-17 11:39 | 显示全部楼层
给你翻译下:
一个IC中的“DGND”表示这个脚是连接到该IC内部的数字地。
但这并不意味着该脚必须接到系统的数字地。
ground plane.
这样的安排,的确会将少量的数字噪声引入到模拟地平面中。
然而,IC的数字地电流应该是非常小的。并且,通过确保(模数)转换器的(数字)输出不驱动重负载
可以使IC的数字地电流达到最小。
减少转换器的数字端口负载(注:原文为扇出,就是同时驱动多少个门的意思,我翻译为负载,
负载包括动态和静态的)还可以减少翻转电流和避免出现振铃,这就减少了任何潜在的耦合
混入到转换起的模拟端口中。
The logic supply pin (VD) can be further isolated from the analog supply by the insertion
of a small lossy ferrite bead as shown in Figure 9.26.
如图9.26所示,通过插入一个有损耗的小铁氧体磁珠,数字电源(VD)可以进一步与模拟电源隔离。
The internal transient digital currents of the converter will flow in the small loop from
VD through the decoupling capacitor and to DGND (this path is shown with a heavy line on
the diagram).
转换器内部的数字毛刺电流将从VD通过退耦电容到DGND这个小环路流过(该路径在图中用粗线标出)。
The transient digital currents will therefore not appear on the external analog ground plane,
 but are confined to the loop.
因此,数字毛刺电流不会在外面的模拟地平面中出现,仅被限制在该小环内。
VD引脚的退耦电容应该尽可能的靠近转换器放置,以使寄生电感最小。
These decoupling capacitors should be low inductance ceramic types,
这些退耦电容应该是低感抗的陶瓷电容,容量通常在0.01uF到0.1uF之间。
circuits.
在既有模拟电路又有数字电路的IC内部(例如ADC或者DAC),数字地和模拟地通常是分开的以避免
数字信号耦合到模拟电路中。
图9.26给出了一个转换器的简易模型。
There is nothing the IC designer can do about the wirebond inductance and resistance
 associated with connecting the bond pads on the chip to the package pins except to
realize it's there.
IC设计人员对于连接芯片和封装引脚之间的绑定线的电感和电阻,除了知道它的存在之外,无计可施。
The rapidly changing digital currents produce a voltage at point B which will inevitably
couple into point A of the analog circuits through the stray capacitance, CSTRAY.
迅速变化的数字电流在B点产生一个电压,它将不可避免的通过寄生电容CSTRAY耦合到模拟电路的A点。
In addition, there is approximately 0.2-pF unavoidable stray capacitance between every
pin of the IC package! It's the IC designer's job to make the chip work in spite of this.
另外,在IC封装的引脚之间,不可避免的存在着约0.2pF的寄生电容。IC设计者有义务让芯片在这种条件下
也能很好的工作。
 However, in order to prevent further coupling, the AGND and DGND pins should be joined
然而,为了避免更多的耦合,AGND和DGND引脚应该在外部连在一起并通过最短的引线连接到模拟地平面。
 Any extra impedance in the DGND connection will cause more digital noise to be developed
at point B; it will, in turn, couple more digital noise into the analog circuit through
任何额外的DGND连接阻抗将会导致B点出现更多的数字噪声;通过寄生电容,这将会有更多的数字噪声
耦合到模拟电路中。
注意,连接DGND到数字地平面将会把VNOISE引入到AGND和DGND并惹来天灾!
跬步 发表于 2008-6-18 00:50 | 显示全部楼层
有没有完整的资料
楼主有没有完整的资料,传上一篇看看,谢谢
computer00 发表于 2008-6-18 01:35 | 显示全部楼层
 楼主| mygaojian 发表于 2008-6-18 10:03 | 显示全部楼层
这么说
那么AD转换芯片的管脚标有DGND的,如果说是分割地,那么不连接数字地?
要连接模拟地?
如果连接了模拟地,那么AD驱动信号是从一个数字芯片来,例如FPGA,那么FPGA到AD的驱动信号的返回路径就经过模拟地了,这样会干扰模拟地平面啊?
就是所谓的跨电路板的分割区域布线了。
这怎么解决?
有兴趣的讨乱下。
longtsuan 发表于 2008-6-18 16:16 | 显示全部楼层
实践中,一直都是AGND接模拟地,DGND接数字地
也没出什么毛病。
原文中如是说:
“Note that connecting DGND to the digital ground plane applies VNOISE across the
AGND and DGND pins and invites disaster!”
disaster?
 楼主| mygaojian 发表于 2008-6-19 08:54 | 显示全部楼层
有点乱
有点乱
数字地管脚是连接到模拟地层,还是连接到数字地层。
是分模拟地层还是分数字地层。
qx7873087 发表于 2010-10-28 11:26 | 显示全部楼层
顶一个,就应该都连模拟地!
lovedfrien 发表于 2010-10-28 20:33 | 显示全部楼层
当然要分开连了,数字地管脚是连接到数字地层,模拟连接到数字地层,不然为什么要分数字地,模拟地
1189594 发表于 2010-10-28 21:17 | 显示全部楼层
呵呵   来学习一下   一直以来   只知道要连在一起  不知道为什么   今天见识啦
