运行ppp-on脚本后<br />通过命令cat /var/log/messages查看系统信息如下: <br />Aug 25 20:30:28 localhost pppd[18563]: pppd 2.4.1 started by root, uid 0 <br />Aug 25 20:30:29 localhost chat[18564]: timeout set to 3 seconds <br />Aug 25 20:30:29 localhost chat[18564]: abort on (\nBUSY\r) <br />Aug 25 20:30:29 localhost chat[18564]: abort on (\nNO ANSWER\r) <br />Aug 25 20:30:29 localhost chat[18564]: abort on (\nRINGING\r\n\r\nRINGING\r) <br />Aug 25 20:30:29 localhost chat[18564]: send (rAT^M) <br />Aug 25 20:30:29 localhost chat[18564]: expect (OK) <br />Aug 25 20:30:29 localhost chat[18564]: AT^M^M <br />Aug 25 20:30:29 localhost chat[18564]: OK <br />Aug 25 20:30:29 localhost chat[18564]: -- got it <br />Aug 25 20:30:29 localhost chat[18564]: send (ATH0^M) <br />Aug 25 20:30:30 localhost chat[18564]: timeout set to 30 seconds <br />Aug 25 20:30:30 localhost chat[18564]: expect (OK) <br />Aug 25 20:30:30 localhost chat[18564]: ^M <br />Aug 25 20:30:30 localhost chat[18564]: ATH0^M^M <br />Aug 25 20:30:30 localhost chat[18564]: OK <br />Aug 25 20:30:30 localhost chat[18564]: -- got it <br />Aug 25 20:30:30 localhost chat[18564]: send (AT+IPR=38400^M) <br />Aug 25 20:30:30 localhost chat[18564]: expect (OK) <br />Aug 25 20:30:30 localhost chat[18564]: ^M <br />Aug 25 20:30:30 localhost chat[18564]: AT+IPR=38400^M^M <br />Aug 25 20:30:30 localhost chat[18564]: OK <br />Aug 25 20:30:30 localhost chat[18564]: -- got it <br />Aug 25 20:30:30 localhost chat[18564]: send (AT+CGDCONT=1,IP,CMNET^M) <br />Aug 25 20:30:30 localhost chat[18564]: expect (OK) <br />Aug 25 20:30:30 localhost chat[18564]: ^M <br />Aug 25 20:30:30 localhost chat[18564]: AT+CGDCONT=1,IP,CMNET^M^M <br />Aug 25 20:30:30 localhost chat[18564]: OK <br />Aug 25 20:30:30 localhost chat[18564]: -- got it <br />Aug 25 20:30:30 localhost chat[18564]: send (AT+CGACT=1,1^M) <br />Aug 25 20:30:31 localhost chat[18564]: expect (OK) <br />Aug 25 20:30:31 localhost chat[18564]: ^M <br />Aug 25 20:30:31 localhost chat[18564]: AT+CGACT=1,1^M^M <br />Aug 25 20:30:31 localhost chat[18564]: OK <br />Aug 25 20:30:31 localhost chat[18564]: -- got it <br />Aug 25 20:30:31 localhost chat[18564]: send (ATDT*99***1#^M) <br />Aug 25 20:30:32 localhost chat[18564]: expect (CONNECT) <br />Aug 25 20:30:32 localhost chat[18564]: ^M <br />Aug 25 20:30:33 localhost chat[18564]: ATDT*99***1#^M^M <br />Aug 25 20:30:33 localhost chat[18564]: CONNECT <br />Aug 25 20:30:33 localhost chat[18564]: -- got it <br />Aug 25 20:30:33 localhost chat[18564]: send (^M) <br />Aug 25 20:30:33 localhost pppd[18563]: Serial connection established. <br />Aug 25 20:30:33 localhost pppd[18563]: Using interface ppp0 <br />Aug 25 20:30:33 localhost pppd[18563]: Connect: ppp0 <--> /dev/ttyS0 <br />Aug 25 20:30:35 localhost modprobe: modprobe: Can't locate module ppp-compress-21 <br />Aug 25 20:30:35 localhost modprobe: modprobe: Can't locate module ppp-compress-21 <br />Aug 25 20:30:36 localhost pppd[18563]: not replacing existing default route to eth0 [192.168.73.1] <br />Aug 25 20:30:36 localhost pppd[18563]: local IP address 10.127.189.237 <br />Aug 25 20:30:36 localhost pppd[18563]: remote IP address 192.168.254.254 <br />最后两行是不是说明已经连上GPRS网络了,192.168.254.254是不是网关,为什么ping 192.168.254.254 ping不通 ,外网也ping不通10.127.189.237?<br /><br />请大虾们赐教!<br /><br /><br /> |
