What define Cgb Cdb in hspice simulation? Help!
3126|1
 楼主| xiexi2001 发表于 2007-9-27 10:26 | 显示全部楼层 |阅读模式
The Cgb and Cdb is defined by layout diffusion size which is AD, PD, AS, PS. But I am confused that when I simulate using level 49 model the Cgb and Cdb exist without writing AD, PD, AS, PS parameter. I wonder how to defind these parameters in hspice program if I don't write them. Thanks!
microe 发表于 2007-9-29 13:46 | 显示全部楼层
re
<br />Spice&nbsp;will&nbsp;use&nbsp;default&nbsp;value&nbsp;if&nbsp;you&nbsp;dont&nbsp;specify&nbsp;AD&nbsp;PD&nbsp;AS&nbsp;PS.<br />Check&nbsp;spice&nbsp;manual&nbsp;or&nbsp;google&nbsp;it.
