- int application_start(void)
- app_log_trace();
- OSStatus err = kNoErr;
- app_context_t* app_context;
- mico_Context_t* mico_context;
- LinkStatusTypeDef wifi_link_status;
- /* Create application context */
- app_context = ( app_context_t *)calloc(1, sizeof(app_context_t) );
- require_action( app_context, exit, err = kNoMemoryErr );
- /* Create mico system context and read application's config data from flash */
- mico_context = mico_system_context_init( sizeof( application_config_t) );
- require_action(mico_context, exit, err = kNoResourcesErr);
- app_context->appConfig = mico_system_context_get_user_data( mico_context );
- app_context->mico_context = mico_context;
- app_context_global = app_context;
- /* user params restore check */
- if(app_context->appConfig->configDataVer != CONFIGURATION_VERSION){
- err = mico_system_context_restore(mico_context);
- require_noerr( err, exit );
- /* mico system initialize */
- err = mico_system_init( mico_context );
- MicoSysLed(true);
- // fix for AP down problem
- err = mico_system_notify_register( mico_notify_WIFI_CONNECT_FAILED, (void *)appNotify_ConnectFailedHandler, app_context->mico_context );
- require_noerr_action(err, exit, app_log("ERROR: MICOAddNotification (mico_notify_WIFI_CONNECT_FAILED) failed!") );
- // block here if no wifi configuration.
- while(1){
- if( mico_context->flashContentInRam.micoSystemConfig.configured == wLanUnConfigured ||
- mico_context->flashContentInRam.micoSystemConfig.configured == unConfigured){
- mico_thread_msleep(100);
- else{
- break;
- /* Bonjour for service searching */
- MICOStartBonjourService( Station, app_context );
- /* check wifi link status */
- do{
- err = micoWlanGetLinkStatus(&wifi_link_status);
- if(kNoErr != err){
- mico_thread_sleep(1);
- }while(kNoErr != err);
- if(1 == wifi_link_status.is_connected){
- app_context->appStatus.isWifiConnected = true;
- MicoRfLed(true);
- else{
- app_context->appStatus.isWifiConnected = false;
- MicoRfLed(false);
- /* start cloud service */
- #if (MICO_CLOUD_TYPE == CLOUD_FOGCLOUD)
- app_log("MICO CloudService: FogCloud.");
- err = MiCOStartFogCloudService( app_context );
- require_noerr_action( err, exit, app_log("ERROR: Unable to start FogCloud service.") );
- #elif (MICO_CLOUD_TYPE == CLOUD_ALINK)
- app_log("MICO CloudService: Alink.");
- #elif (MICO_CLOUD_TYPE == CLOUD_DISABLED)
- app_log("MICO CloudService: disabled.");
- #else
- #error "MICO cloud service type is not defined"
- #endif
- /* start user thread */
- err = startUserMainThread( app_context );
- require_noerr_action( err, exit, app_log("ERROR: start user_main thread failed!") );
- exit:
- mico_rtos_delete_thread(NULL);
- return err;
