[STM32F4] STM32F407VET6 FSMC有问。
1459|0
 楼主| oo无忧草 发表于 2016-9-1 21:15 | 显示全部楼层 |阅读模式
各路大神, 我在用STM32F4的FSMC驱动TFT时,发现NE1的输出信号有点奇怪。请问各位会出现这种情况吗?还是我的配置有问题??后来我用手中的103也看了下输出的波型, 使能时并没发现有图中的突起信号。请求各路大神帮忙解答下,谢谢~~
如图:
配置:
                GPIO_InitTypeDef GPIO_InitStruct;
                FSMC_NORSRAMInitTypeDef FSMC_InitStruct;
                FSMC_NORSRAMTimingInitTypeDef FSMC_ReadTiming;
                FSMC_NORSRAMTimingInitTypeDef FSMC_WriteTiming;
                GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7
        |GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14|GPIO_Pin_15|GPIO_Pin_11;
                GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;                      /*>¸´Óù¦ÄÜ            */
                GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
                GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_DOWN;
                GPIO_InitStruct.GPIO_Speed = GPIO_Fast_Speed;                  /*>50MHz  */
                GPIO_Init(GPIOD, &GPIO_InitStruct);
                GPIOD->AFR[0] = (GPIOD->AFR[0]&(0X0F00FF00))|0XC0CC00CC;
                GPIOD->AFR[1] = (GPIOD->AFR[1]&(0X00FF0000))|0XCC00CCCC;
          GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11
        |GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
          GPIO_Init(GPIOE, &GPIO_InitStruct);
          GPIOE->AFR[0] = (GPIOE->AFR[0]&(0X0FFFFFFF))|0XC0000000;
          GPIOE->AFR[1] = (GPIOE->AFR[1]&(0X00000000))|0XCCCCCCCC;
          GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12;
          GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;                     /*>¸´Óù¦ÄÜ            */
          GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;
          GPIO_InitStruct.GPIO_Speed = GPIO_Low_Speed;                   /*>50MHz  */
                FSMC_ReadTiming.FSMC_AccessMode = FSMC_AccessMode_B ;
                FSMC_ReadTiming.FSMC_AddressHoldTime = 0x0F;
                FSMC_ReadTiming.FSMC_AddressSetupTime = 0x0F;
                FSMC_ReadTiming.FSMC_BusTurnAroundDuration = 0x00;
                FSMC_ReadTiming.FSMC_DataSetupTime    = 0x20;
                FSMC_WriteTiming.FSMC_AccessMode = FSMC_AccessMode_B ;
                FSMC_WriteTiming.FSMC_AddressHoldTime = 15;
                FSMC_WriteTiming.FSMC_AddressSetupTime = 15;
                FSMC_WriteTiming.FSMC_BusTurnAroundDuration = 0x00;
                FSMC_WriteTiming.FSMC_DataSetupTime    = 0x15;
                FSMC_WriteTiming.FSMC_DataLatency = 0x0f;
                FSMC_InitStruct.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable ;
                FSMC_InitStruct.FSMC_Bank             = FSMC_Bank1_NORSRAM1;
                FSMC_InitStruct.FSMC_BurstAccessMode  = FSMC_BurstAccessMode_Disable;
                FSMC_InitStruct.FSMC_DataAddressMux   = FSMC_DataAddressMux_Enable;
                FSMC_InitStruct.FSMC_ExtendedMode     = FSMC_ExtendedMode_Enable;
                FSMC_InitStruct.FSMC_MemoryDataWidth  = FSMC_MemoryDataWidth_16b;
                FSMC_InitStruct.FSMC_MemoryType       = FSMC_MemoryType_NOR;
                FSMC_InitStruct.FSMC_WriteBurst       = FSMC_WriteBurst_Disable;
                FSMC_InitStruct.FSMC_WriteOperation   = FSMC_WriteOperation_Enable;
                FSMC_InitStruct.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
                FSMC_InitStruct.FSMC_WrapMode         = FSMC_WrapMode_Disable;
                FSMC_InitStruct.FSMC_WaitSignal       = FSMC_WaitSignal_Disable;
                FSMC_InitStruct.FSMC_ReadWriteTimingStruct = &FSMC_ReadTiming;
                FSMC_InitStruct.FSMC_WriteTimingStruct = &FSMC_WriteTiming;
                FSMC_NORSRAMInit(&FSMC_InitStruct);
                FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
NE的输出信号
NE的输出信号
