[STM32F4] 再次分享一个自己的例程,串口生成的32Bit随机数STMF4...
1028|2
 楼主| zhdwdf66 发表于 2016-9-2 14:05 | 显示全部楼层 |阅读模式
  * @file    Timer.c
  * @author  WB R&D Team - openmcu666
  * @version V0.1
  * @date    2015.7.9
  * @brief   Timer
#include "Timer.h"
__IO uint32_t TimingDelay = 0;
__IO uint32_t CaptureNumber = 0;
__IO uint32_t PeriodValue = 0;
  * @brief  Configures TIM5 to measure the LSI oscillator frequency.
  * @param  None
  * @retval LSI Frequency
uint32_t GetLSIFrequency(void)
  NVIC_InitTypeDef   NVIC_InitStructure;
  TIM_ICInitTypeDef  TIM_ICInitStructure;
  RCC_ClocksTypeDef  RCC_ClockFreq;
  RCC_LSICmd(ENABLE);                                              //使能LSI
  while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)              //等待LSI稳定
  /* TIM5 configuration *******************************************************/
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);            //使能TIM5时钟
  TIM_RemapConfig(TIM5, TIM5_LSI);                                //内部TIM5_CH4输入捕获连接到LSI时钟输出
  TIM_PrescalerConfig(TIM5, 0, TIM_PSCReloadMode_Immediate);      //设置预分频
  /* TIM5 configuration: Input Capture mode ---------------------
     The LSI oscillator is connected to TIM5 CH4
     The Rising edge is used as active edge,
     The TIM5 CCR4 is used to compute the frequency value
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_4;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV8;
  TIM_ICInitStructure.TIM_ICFilter = 0;
  TIM_ICInit(TIM5, &TIM_ICInitStructure);
  /* Enable TIM5 Interrupt channel */
  NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  TIM_Cmd(TIM5, ENABLE);                                    //启动计数器
  TIM5->SR = 0;                                             //Reset the flags
  TIM_ITConfig(TIM5, TIM_IT_CC4, ENABLE);                   //启动CC4中断请求
  /* Wait until the TIM5 get 2 LSI edges (refer to TIM5_IRQHandler() in
    stm32f4xx_it.c file) ******************************************************/
  while(CaptureNumber != 2)
  TIM_DeInit(TIM5);                                            //设置为复位后的默认值
  RCC_GetClocksFreq(&RCC_ClockFreq);                           //获取系统时钟,HCLK 和 PCLKx 频率
  if ((RCC->CFGR & RCC_CFGR_PPRE1) == 0)                       //获取PCLK1预分频器
    return ((RCC_ClockFreq.PCLK1_Frequency / PeriodValue) * 8);//PCLK1预分频器
  else
    return (((2 * RCC_ClockFreq.PCLK1_Frequency) / PeriodValue) * 8) ;
** 实验名:旺宝-红龙429-RNG实验
** KEIL MDK-ARM Standard Version:V5.10
** 软件库(keil) Version: unused
** 固件库(ST) Version: 1.5.0
** 使用外设:
** 实验说明:
实验原理:
硬件连接:
实验现象:程序运行后,串口打印RNG生成的32Bit随机数.
【11】红龙429_RNG(2015.10.10).rar
60.67 KB, 下载次数: 4
mmuuss586 发表于 2016-9-2 14:13 | 显示全部楼层
谢谢分享;
 楼主| zhdwdf66 发表于 2016-9-5 14:02 | 显示全部楼层
