[STM32F0] stm32f030k6t6的TIM3有问题??
962|1
 楼主| lizhenming 发表于 2017-2-5 12:34 | 显示全部楼层 |阅读模式
情况如下,看手册TIM3对应的引脚是PA6 PA7 PB0 PB1 或者PB4 PB5 PB0 PB1但是我配置PA6 PA7 PB0 PB1 这四路就有PWM输出,而配置PB4 PB5 PB0 PB1这四路就不行,
1. PA6 PA7 PB0 PB1
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE );
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource0,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource1,GPIO_AF_1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        TIM_TimeBaseStructure.TIM_Period = 9000;
        TIM_TimeBaseStructure.TIM_Prescaler = 1;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_Pulse = 0;
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OC1Init(TIM3, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_OC4Init(TIM3, &TIM_OCInitStructure);
        TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3, ENABLE);
        TIM_Cmd(TIM3, ENABLE);
        TIM3->CCR1 = 8000;//0;
        TIM3->CCR2 = 8000;//0;
        TIM3->CCR3 = 8000;//0;
        TIM3->CCR4 = 8000;//0;
2, PB4 PB5 PB0 PB1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
xyz549040622 发表于 2017-2-6 08:21 | 显示全部楼层
肯定没有问题,跑官方的例程看看。不要立马怀疑是片子的问题
