| 小生我想做一个定时中断来点灯与关闭LED 指示灯,碰到问题,希望各位大侠鼎力相助,不胜感谢! 源程序如下:
 #include "LPC23xx.H"                        /* LPC23xx/24xx definitions */
 #include "type.h"
 #include "target.h"
 #include "irq.h"
 #include "timer.h"
 #define LED 1<<7
 void __irq timer0_ISR (void);
 INT8U timer0Times = 0;
 void timer0Init (void)
 T1MR0 = 119999;/*匹配寄存器,120000-1,12000000为1秒*/
 T1MCR = 0x03;/*产生中断,重置TC*/
 T1TCR = 0x01;/*使能定时计数器0*/
 VICIntSelect = 0x00000000;
 VICIntEnable = 0x00000030;/*开定时计数器1中断*/
 //   VICIntEnable = 0x00000020;/*开定时计数器1中断*/
 VICVectAddr1 = (unsigned long)timer0_ISR;
 VICVectCntl1 = 0x20 | 5;/*定时器计数器1为5号中断*/
 void timer0_ISR (void) __irq
 uint32  i;
 timer0Times++;
 if(timer0Times == 10)
 i=IOSET0;                         //读出当前LED2控制值
 if((i&LED)==0)
 IOSET0=LED;
 else
 IOCLR0=LED;
 timer0Times = 0;
 T1IR = 1;/*清除定时器0中断*/
 VICVectAddr = 0;
 **main
 int main(void)
 timer0Init();
 IODIR0=0x00000080;
 T1TCR = 0x00;
 // IOSET0 = LED;
 IOCLR0 = LED;
 return 0;
