[开发工具] STVP问题。。
1546|1
 楼主| iangzy 发表于 2017-4-28 12:13 | 显示全部楼层 |阅读模式
ST, tv, se, link, ck
我用IAR可以烧写程序,用STVP为何总是提示错误
用的是ST-Link-V2
  1. Error : Cannot communicate with the tool.
  2. Wrong tool selection or check tool power supply or check that a previous session is closed.
  3. Error : Check and install the RLink driver, with shortcut start/Programs/ST Toolset/Setup/Install RLink driver
  4. Error : < PROGRAM MEMORY reading failed
mmuuss586 发表于 2017-4-28 20:28 | 显示全部楼层
可能和STVP软件兼容性有关吧;
IAR没问题,就用IAR好了
