[应用相关] 请教i2c通讯mma8451的读出的数据都是ff问题。cube生成的程序
2052|4
 楼主| 123782568 发表于 2017-6-24 17:43 | 显示全部楼层 |阅读模式
今天调了一天,一开始地址写0x1c,i2c出错。之后改成0x38.就没问题了。但是读出的数据有问题,所有的都是ff。一直找不到问题。望各位帮看看。
/*                               MMA8451.c
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* -- COPYRIGHT-- */
//   F. Chen
//   Texas Instruments Inc.
//   Dec. 2012
//   Built with CCS Version: 5.2.1 and IAR Embedded Workbench Version: 5.51.1
#include "i2c.h"
#include "gpio.h"
#include "include.h"
#include "math.h"
#define I2C1_WRITE_ADDRESS 0x38
#define I2C1_READ_ADDRESS  0x38
unsigned char  Stop = 0;
unsigned char  MMA845x_flag = 0;
unsigned char  ReadOutData[6];                // Read out from MMA845x
signed   int   Gx, Gy, Gz;           // X, Y, Z
**                           I2C Configeration
void I2C_RegWrite(unsigned char Reg, unsigned char data)
         uint8_t TxData[2] = {Reg,data};
   while(HAL_I2C_Master_Transmit(&hi2c1,I2C1_WRITE_ADDRESS,(uint8_t*)TxData,2,1000) != HAL_OK)
       if (HAL_I2C_GetError(&hi2c1) != HAL_I2C_ERROR_AF)
           Error_Handler();
unsigned char I2C_RegRead(uint8_t REG_Address)
         uint8_t RxBuffer;
         while(HAL_I2C_Master_Transmit(&hi2c1,I2C1_WRITE_ADDRESS,&REG_Address,1,500) != HAL_OK)
                  Error_Handler();
    if(HAL_I2C_Master_Receive(&hi2c1,I2C1_READ_ADDRESS,&RxBuffer,1,500) != HAL_OK)
                  Error_Handler();
    return RxBuffer;
void I2C_MultiRegsRead(unsigned char Reg, unsigned char *data)
                data[0] = I2C_RegRead(0x01);
                data[1] = I2C_RegRead(0x02);
                data[2] = I2C_RegRead(0x03);
                data[3] = I2C_RegRead(0x04);
                data[4] = I2C_RegRead(0x05);
                data[5] = I2C_RegRead(0x06);
**                        MMA845x Configeration
#define   WHO_AM_I     0x0D
#define   DATA_CFG     0x0E
#define   HP_FILTER    0x0F
#define   CTRL_REG1    0x2A
#define   CTRL_REG2    0x2B
#define   CTRL_REG3    0x2C
#define   CTRL_REG4    0x2D
#define   CTRL_REG5    0x2E
void MMA845x_Reset(void)
    unsigned char RST = 1 << 6;
    I2C_RegWrite(CTRL_REG2, RST);
    HAL_Delay(500);
        //__delay_cycles(10000);
void MMA845x_Standby(void)
    unsigned char ACTIVE = 0x01;
    I2C_RegWrite(CTRL_REG1, (I2C_RegRead(CTRL_REG1) & ~ACTIVE));
void MMA845x_OutputDataRate(void)
    unsigned char DR = 6 << 3;                // DR[2:0] = 110, 6.25Hz
    I2C_RegWrite(CTRL_REG1, (I2C_RegRead(CTRL_REG1) | DR));
void MMA845x_OverSamplingMode(void)
    unsigned char MODS = 0x01;                // MODS[1:0] = 01, Low Power
    I2C_RegWrite(CTRL_REG2, (I2C_RegRead(CTRL_REG2) | MODS));
void MMA845x_FilterCutoff(void)
    unsigned char HPF_BYP = 1 << 5;
    unsigned char LPF_EN  = 1 << 4;
    I2C_RegWrite(HP_FILTER, (I2C_RegRead(HP_FILTER) | HPF_BYP));
    I2C_RegWrite(HP_FILTER, (I2C_RegRead(HP_FILTER) | LPF_EN));
void MMA845x_InterruptPolarity(void)
    unsigned char PP_OD = 0x01;               // Open-Drain on interrupt pad
    I2C_RegWrite(CTRL_REG2, (I2C_RegRead(CTRL_REG2) | PP_OD));
void MMA845x_InterruptEnable(void)
    unsigned char INT_EN_DRDY = 0x01;         // Data Ready interrupt enable
    I2C_RegWrite(CTRL_REG4, (I2C_RegRead(CTRL_REG4) | INT_EN_DRDY));
void MMA845x_InterruptConfig(void)
    unsigned char INT_CONFIG_DRDY = 0x01;     // Interrupt is routed to INT1 pin
    I2C_RegWrite(CTRL_REG5, (I2C_RegRead(CTRL_REG5) | INT_CONFIG_DRDY));
void MMA845x_Active(void)
    I2C_RegWrite(CTRL_REG1, (I2C_RegRead(CTRL_REG1) | ACTIVE));
void MMA845x_Init(void)
//                MX_I2C1_Init();
                MMA845x_Reset();
        //        MMA845x_Standby();
                //MMA845x_OutputDataRate();
        //        MMA845x_OverSamplingMode();
                MMA845x_FilterCutoff();
                MMA845x_InterruptPolarity();
                MMA845x_InterruptConfig();
                MMA845x_InterruptEnable();
                MMA845x_Active();
//        Single_Write(MMA845x_IIC_ADDRESS,CTRL_REG1,ASLP_RATE_20MS+DATA_RATE_5MS);
//        Single_Write(MMA845x_IIC_ADDRESS,XYZ_DATA_CFG_REG, FULL_SCALE_2G);
//        Single_Write(MMA845x_IIC_ADDRESS,CTRL_REG1, ACTIVE_MASK);
//          I2C_RegWrite(CTRL_REG1, 0x10);
//                I2C_RegWrite(0x0E, 0x00);
//          MMA845x_Active();
//                //I2C_RegWrite(CTRL_REG1, 0x10);
void MMA845x_ReadXYZ(void)
    I2C_MultiRegsRead(0x01, ReadOutData);
    Gx = (ReadOutData[0] << 8) | ReadOutData[1];
    Gy = (ReadOutData[2] << 8) | ReadOutData[3];
    Gz = (ReadOutData[4] << 8) | ReadOutData[5];
 楼主| 123782568 发表于 2017-6-24 19:25 来自手机 | 显示全部楼层
顶下,同学们,帮看看吧
 楼主| 123782568 发表于 2017-6-25 15:05 | 显示全部楼层
都快沉了。有朋友帮忙看下么
 楼主| 123782568 发表于 2017-6-27 08:56 | 显示全部楼层
程序能读出来了,但用的是  HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x01, 1, &data[0], 1, 35);
                 HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x02, 1, &data[1], 1, 35);
                 HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x03, 1, &data[2], 1, 35);
                 HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x04, 1, &data[3], 1, 35);
                 HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x05, 1, &data[4], 1, 35);
                 HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x06, 1, &data[5], 1, 35);
           //HAL_I2C_Mem_Read(&hi2c1, I2C1_READ_ADDRESS, 0x01, 0x06, data, 6, 3500);
这个函数。用那个hal-i2ctransmit 和个hal-i2crecive函数怎么也不行.还有就是我用HAL_I2C_Mem_Read这个函数一起读6个寄存器也读不出(见最后一行)。真是搞不明白。
