| 在此之前是能成功连接并运行程序,得到正确结果的。前两天能连上的并能运行程序,但实验过程出了点问题,没有停止程序就断了电。 之后换了个调试的程序
 编译出现这个
 gmake: Nothing to be done for `all'.
 之后DEBUG出现以下几种错误
 C28xx: Error connecting to the target: (Error -171 @ 0x0) The wrong controller address value has been used. A controller cannot be detected even though the selected port does match the hardware configuration. (Emulation package 5.1.232.0)
 (Error -342 @ 0x0)
 Failure due to the controller command-finish taking too long.
 再换回两天前能连接上的程序也还是出现这些连接不上仿真器的问题
 求助!!
