[STM8] STM8S003 LIN主模式输出低电平异常
1381|0
 楼主| phenixyf 发表于 2017-8-2 15:36 | 显示全部楼层 |阅读模式
使用STM8S003的UART1作为LIN主模式,配置之后,低电平输出异常,代码如下,请大侠们看下
**函数名称:LinMasterInit()
**功能描述:Uart Lin Master Mode Initial
**入口参数:unsigned int  baudrate        Uart波特率
**输出:无
void LinMasterInit(unsigned int  baudrate)
  unsigned int baud;              //
  UART1_CR1_bit.M = 0;                                //set word length
  UART1_CR3_bit.STOP = 0;                        //set stop bit num.
  UART1_CR3_bit.CKEN = 0;
  UART1_CR5_bit.SCEN = 0;
  UART1_CR5_bit.HDSEL = 0;
  UART1_CR5_bit.IREN = 0;
  baud = 16000000 / baudrate;     //设定串口相应波特率与串口时钟的分频数
  //先写BRR2 , 再写BRR1
  UART1_BRR2 = ((unsigned char)((baud & 0xf000) >> 8 )) | ((unsigned char)(baud & 0x000f));       //先写波特比率的高4位与低4位
  UART1_BRR1 =  ((unsigned char)((baud & 0x0ff0) >> 4));                                          //后写波特比率的中间8位;
  UART1_CR3_bit.LINEN = 1;                        //enable LIN mode
  UART1_CR2_bit.TEN = 1;                        //enable transmit
  UART1_CR2_bit.REN = 1;                        //enable receive
/* 主函数 */
int main(void)
  CLK_CKDIVR = 0x00;      //内部时钟为1分频 = 16Mhz
  LinMasterInit(19200);         //调用LED灯初始化函数,
  while(1)
      UART1_CR2_bit.SBK = 1;
    while(!(UART1_SR&0X80));
    UART1_DR = 0x01;
    while(!UART1_SR_bit.TC);
    UART1_DR = 0x00;
    delay(300);
