请教C8051单片机的时钟问题
5526|19
 楼主| dccdaa2222 发表于 2011-1-4 09:38 | 显示全部楼层 |阅读模式
有用过的C8051F340单片机高手指点一下:
      我想一个12M 或是11.0592M的晶振该怎样配置!!!!谢谢!!!!!
ayb_ice 发表于 2011-1-4 09:44 | 显示全部楼层
//  Generated Initialization File  //
#include "C8051F340.h"
// Peripheral specific initialization functions,
// Called from the Init_Device() function
void PCA_Init()
    PCA0MD    &= ~0x40;
    PCA0MD    = 0x00;
void Port_IO_Init()
    // P0.0  -  Unassigned,  Open-Drain, Digital
    // P0.1  -  Unassigned,  Open-Drain, Digital
    // P0.2  -  Unassigned,  Open-Drain, Digital
    // P0.3  -  Unassigned,  Open-Drain, Digital
    // P0.4  -  Unassigned,  Open-Drain, Digital
    // P0.5  -  Unassigned,  Open-Drain, Digital
    // P0.6  -  Skipped,     Open-Drain, Analog
    // P0.7  -  Skipped,     Open-Drain, Analog
    // P1.0  -  Unassigned,  Open-Drain, Digital
    // P1.1  -  Unassigned,  Open-Drain, Digital
    // P1.2  -  Unassigned,  Open-Drain, Digital
    // P1.3  -  Unassigned,  Open-Drain, Digital
    // P1.4  -  Unassigned,  Open-Drain, Digital
    // P1.5  -  Unassigned,  Open-Drain, Digital
    // P1.6  -  Unassigned,  Open-Drain, Digital
    // P1.7  -  Unassigned,  Open-Drain, Digital
    // P2.0  -  Unassigned,  Open-Drain, Digital
    // P2.1  -  Unassigned,  Open-Drain, Digital
    // P2.2  -  Unassigned,  Open-Drain, Digital
    // P2.3  -  Unassigned,  Open-Drain, Digital
    // P2.4  -  Unassigned,  Open-Drain, Digital
    // P2.5  -  Unassigned,  Open-Drain, Digital
    // P2.6  -  Unassigned,  Open-Drain, Digital
    // P2.7  -  Unassigned,  Open-Drain, Digital
    // P3.0  -  Unassigned,  Open-Drain, Digital
    // P3.1  -  Unassigned,  Open-Drain, Digital
    // P3.2  -  Unassigned,  Open-Drain, Digital
    // P3.3  -  Unassigned,  Open-Drain, Digital
    // P3.4  -  Unassigned,  Open-Drain, Digital
    // P3.5  -  Unassigned,  Open-Drain, Digital
    // P3.6  -  Unassigned,  Open-Drain, Digital
    // P3.7  -  Unassigned,  Open-Drain, Digital
    P0MDIN    = 0x3F;
    P0SKIP    = 0xC0;
void Oscillator_Init()
    int i = 0;
    OSCXCN    = 0x67;
    for (i = 0; i < 3000; i++);  // Wait 1ms for initialization
    while ((OSCXCN & 0x80) == 0);
    CLKSEL    = 0x01;
// Initialization function for device,
// Call Init_Device() from your main program
void Init_Device(void)
    PCA_Init();
    Port_IO_Init();
    Oscillator_Init();
void main(void)
    Init_Device();
    while(1)
empty_net 发表于 2011-1-4 10:14 | 显示全部楼层
抢沙发
airwill 发表于 2011-1-4 10:34 | 显示全部楼层
乍一看, 好象很复杂.
细看, 原来就配置一下 I/O 端口,  切换设置一下时钟.
恳请 2 楼在回复时, 可以先精简一下, 再出牌.
哈哈哈哈......
ayb_ice 发表于 2011-1-4 11:32 | 显示全部楼层
LS
我那是用配置向导产生的代码
lws 发表于 2011-1-4 11:50 | 显示全部楼层
呵呵,用C8051F单片机要尽量用配置向导,楼主估计是没用过吧
 楼主| dccdaa2222 发表于 2011-1-4 13:49 | 显示全部楼层
6楼兄弟说说看怎 么用配置向导.................
OSCXCN=0X67是用外部的晶振了/...请教用内部的可以配置吗?
ayb_ice 发表于 2011-1-4 14:05 | 显示全部楼层
就是这个软件
lws 发表于 2011-1-4 17:43 | 显示全部楼层
7# dccdaa2222
http://www.xhl.com.cn/download.asp?bigdownid=7&bigdownname=调试器
Configuration Wizard 2.90 你用了就知道了。
shell.albert 发表于 2011-1-4 19:28 | 显示全部楼层
仔细看Datasheet,对于有一些外部振荡信号,通过寄存器是查不出来的.之前就犯过这样的错误.仔细看Datasheet!!!!!!!!!!!!!!!!!!
ningling_21 发表于 2011-1-4 20:29 | 显示全部楼层
配置向导方便的很...
我是土匪 发表于 2011-1-5 09:24 | 显示全部楼层
学习了
大秦正声 发表于 2011-1-5 10:05 | 显示全部楼层
内部的12M晶振正常的条件下有+/-1.5%的误差!
校验后可达到+/-0.25%的误差。
使用内部先关狗!
PCA0MD =0;//关闭看门狗
OSCICN=0xc3;//选用内部12MHz
ayb_ice 发表于 2011-1-5 11:45 | 显示全部楼层
校验后可达到+/-0.25%的误差。
使用内部先关狗!
PCA0MD =0;//关闭看门狗
没有说"校验后可达到+/-0.25%的误差。"
出厂时本来就就是经过校准的,手册说的一般是+/-2%,不过保证是在全工作范围的
大秦正声 发表于 2011-1-5 13:16 | 显示全部楼层
c8051f32x/34x出厂校验内部的12M晶振有+/-1.5%的误差!
经过软件设定后usb通信晶振频率有0.25%的误差!
普通的c8051f31x等内部的晶振有+/-2%的误差!
 楼主| dccdaa2222 发表于 2011-1-7 17:09 | 显示全部楼层
为会我用配置向导配出来是:
OSCICN=0x83;
大秦正声 发表于 2011-1-8 12:46 | 显示全部楼层
可以仔细看下边的图片!
就会找到的!
欢迎到我的博客
http://yang96381.blog.163.com/
lvchachey 发表于 2011-8-7 22:23 | 显示全部楼层
C8051的配置向导在哪里下载啊?可不可以给个链接?楼上的已经失效了啊
mixsall 发表于 2011-8-8 02:10 | 显示全部楼层
to 18L
   我有这个 我是从新华龙的网站上面下的  仔细找找就能找到;找不到可以联系我 Q853636827;
289172800 发表于 2011-8-8 17:25 | 显示全部楼层
[b]楼上各位,新华龙单片机手册上面指出 ,ad参考电压要比电源电压低0.3v,大家知道这是为什么吗?如果我参考电压和电源电压接在一起会有什么后果.
我现在手上有个项目是是用c8051f120的,我的ad参考电压接的是3.3v,和电源电压接在一起.现在出现我把ad脚接到地的读出ad不为0.有几十左右的ad值. 接3.3v读出的ad值也不能达到4095. 首先说明一下.我总共用了10个通道. 不是所有的通道都有这个现象.也不是所有的板子有这个现象. 会有一部分板子的某几个通道会有这个现象. 大家看看.这是什么原因. 还有我用烙铁烫下管脚,所有现象都消失了.但过了几个小时有会有这个现象.
