附S3C2440至简中断程序,请帮忙分析下错误
2398|4
 楼主| dosculler 发表于 2011-4-25 09:05 | 显示全部楼层 |阅读模式
//主程序init.c如下
//LED1-4分别为GPF0-3,KEY1-4分别为GPF4-7
#define rGPFCON    (*(volatile unsigned *)0x56000050) //Port F control
#define rGPFDAT    (*(volatile unsigned *)0x56000054) //Port F data
#define rGPFUP     (*(volatile unsigned *)0x56000058) //Pull-up control F
#define rEXTINT0   (*(volatile unsigned *)0x56000088) //External interrupt control register 0
#define rEINTMASK  (*(volatile unsigned *)0x560000a4) //External interrupt mask
#define rEINTPEND  (*(volatile unsigned *)0x560000a8) //External interrupt pending
#define rINTPND     (*(volatile unsigned *)0x4a000010) //Interrupt request status
#define EnableIrq(bit)  rINTMSK &= ~(bit)
#define BIT_EINT4_7   (0x1<<4)
#define LED1ON    0xFE
#define LED2ON    0xFD
#define LED3ON    0xFB
#define LED4ON    0xF7
#define LEDOFF    0xFF            //LED熄灭值为0xFF
void __irq EintHandler(void);
void Main(void)
    rGPFCON = (rGPFCON|0xFFFF)&0xFFFFaa55;  //GPF4-7设置为EINT4-7,GPF0-3为输出
    rGPFUP &= 0xFF00;                      //打开上拉功能
    rGPFDAT |= 0xF;
    rEXTINT0 &= ~(7<<16 | 7<<20 | 7<<24 | 7<<28);
rEXTINT0 |= (2<<16 | 2<<20 | 2<<24 | 2<<28) ;  //设置外部中断4_7下降沿触发
rEINTPEND |= (1<<4|1<<5|1<<6|1<<7);       //clear eint 4
rEINTMASK &= ~(1<<4|1<<5|1<<6|1<<7);      //enable eint 4
// ClearPending(BIT_EINT4_7);
   pISR_EINT4_7=(unsigned)EintHandler;  //外部中断4_7中断服务子程序入口地址
EnableIrq(BIT_EINT4_7);
    while(1);
// 语法格式: void __irq Eint0Handler(void)
// 功能描述: 点亮或者熄灭LED5-8  中断函数
// 入口参数: 无
// 出口参数: 无
if(rINTPND==BIT_EINT4_7)
  if(rEINTPEND&(1<<4))
  // Uart_Printf("eint 4\n");
   rGPFDAT = LED1ON;
  // Delay(500);
   rGPFDAT = LEDOFF;
   rEINTPEND |= 1<< 4;
  if(rEINTPEND&(1<<5))
  // Uart_Printf("eint 5\n");
   rGPFDAT = LED2ON;
  // Delay(500);
   rGPFDAT = LEDOFF;
   rEINTPEND |= 1<< 5;
  if(rEINTPEND&(1<<6))
  // Uart_Printf("eint 6\n");
   rGPFDAT = LED3ON;
  // Delay(500);
   rGPFDAT = LEDOFF;
   rEINTPEND |= 1<< 6;
  if(rEINTPEND&(1<<7))
  // Uart_Printf("eint 7\n");
   rGPFDAT = LED4ON;
  // Delay(500);
   rGPFDAT = LEDOFF;
   rEINTPEND |= 1<< 7;
//Makefile如下:
objs := init.o
int.bin: $(objs)
arm-linux-ld -Ttext 0x00000000 -o int_elf $^
arm-linux-objcopy -O binary -S int_elf $@
arm-linux-objdump -D -m arm int_elf > int.dis
%.o:%.c
arm-linux-gcc -Wall -O2 -c -o $@ $<
%.o:%.S
clean:
rm -f int.bin int_elf int.dis *.o
//另外有2440的一些通用寄存器的宏定义,这个大侠们应该知道
//在执行"make"时出现如下错误,请问是为什么,前辈能花点帮我修改下程序不,刚学,实在是无奈,看不通,非常感谢
 楼主| dosculler 发表于 2011-4-25 16:40 | 显示全部楼层
其实就一条很简单的中断,但不知道为什么,各类书就不是没给出例程,就是给出的例程不能用,或者是给得太复杂了
 楼主| dosculler 发表于 2011-4-26 13:42 | 显示全部楼层
maolz322 发表于 2011-4-26 14:06 | 显示全部楼层
 楼主| dosculler 发表于 2011-4-27 16:14 | 显示全部楼层
无人?为什么这么简单的程序,没有人顺便地说一声,21IC是个什么地方??哎
