[DemoCode下载] N76E003 PWM
2111|15
 楼主| 捉虫天师 发表于 2018-6-28 17:25 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 PWM Output with dead time insert demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "Common.h"
  17. #include "Delay.h"
  18. #include "SFR_Macro.h"
  19. #include "Function_define.h"
  20. //*****************  The Following is in define in Fucntion_define.h  ***************************
  21. //****** Always include Function_define.h call the define you want, detail see main(void) *******
  22. //***********************************************************************************************
  23. #if 0
  24. ////--------- PMW clock source select define ---------------------
  25. //#define                PWM_CLOCK_FSYS                                        CKCON&=0xBF
  26. //#define                PWM_CLOCK_TIMER1                                CKCON|=0x40
  27. ////--------- PWM clock devide define ----------------------------
  28. //#define                PWM_CLOCK_DIV_2                                        PWMCON1|=0x01;PWMCON1&=0xF9
  29. //#define                PWM_CLOCK_DIV_4                                        PWMCON1|=0x02;PWMCON1&=0xFA
  30. //#define                PWM_CLOCK_DIV_8                                        PWMCON1|=0x03;PWMCON1&=0xFB
  31. //#define                PWM_CLOCK_DIV_16                                PWMCON1|=0x04;PWMCON1&=0xFC
  32. //#define                PWM_CLOCK_DIV_32                                PWMCON1|=0x05;PWMCON1&=0xFD
  33. //#define                PWM_CLOCK_DIV_64                                PWMCON1|=0x06;PWMCON1&=0xFE
  34. //#define                PWM_CLOCK_DIV_128                                PWMCON1|=0x07
  35. ////--------- PWM I/O select define ------------------------------
  36. //#define                PWM5_P15_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x20;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.5 as PWM5 output enable
  37. //#define                PWM5_P03_OUTPUT_ENABLE                PIOCON0|=0x20        //P0.3 as PWM5
  38. //#define                PWM4_P01_OUTPUT_ENABLE                PIOCON0|=0x10        //P0.1 as PWM4 output enable
  39. //#define                PWM3_P04_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x08;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P0.4 as PWM3 output enable
  40. //#define                PWM3_P00_OUTPUT_ENABLE                PIOCON0|=0x08        //P0.0 as PWM3
  41. //#define                PWM2_P05_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x04;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.0 as PWM2 output enable
  42. //#define                PWM2_P10_OUTPUT_ENABLE                PIOCON0|=0x04        //P1.0 as PWM2
  43. //#define                PWM1_P14_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x02;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.4 as PWM1 output enable
  44. //#define                PWM1_P11_OUTPUT_ENABLE                PIOCON0|=0x02        //P1.1 as PWM1
  45. //#define                PWM0_P12_OUTPUT_ENABLE                PIOCON0|=0x01        //P1.2 as PWM0 output enable
  46. //#define         ALL_PWM_OUTPUT_ENABLE                        PIOCON0=0xFF;PIOCON1=0xFF
  47. //#define                PWM5_P15_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xDF;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.5 as PWM5 output disable
  48. //#define                PWM5_P03_OUTPUT_DISABLE                PIOCON0&=0xDF        //P0.3 as PWM5
  49. //#define                PWM4_P01_OUTPUT_DISABLE                PIOCON0&=0xEF        //P0.1 as PWM4 output disable
  50. //#define                PWM3_P04_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xF7;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P0.4 as PWM3 output disable
  51. //#define                PWM3_P00_OUTPUT_DISABLE                PIOCON0&=0xF7        //P0.0 as PWM3
  52. //#define                PWM2_P05_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xFB;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.0 as PWM2 output disable
  53. //#define                PWM2_P10_OUTPUT_DISABLE                PIOCON0&=0xFB        //P1.0 as PWM2
  54. //#define                PWM1_P14_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xFD;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.4 as PWM1 output disable
  55. //#define                PWM1_P11_OUTPUT_DISABLE                PIOCON0&=0xFD        //P1.1 as PWM1
  56. //#define                PWM0_P12_OUTPUT_DISABLE                PIOCON0&=0xFE        //P1.2 as PWM0 output disable
  57. //#define         ALL_PWM_OUTPUT_DISABLE                PIOCON0=0x00;PIOCON1=0x00
  58. ////--------- PWM I/O Polarity Control ---------------------------
  59. //#define                PWM5_OUTPUT_INVERSE                        PNP|=0x20
  60. //#define                PWM4_OUTPUT_INVERSE                        PNP|=0x10
  61. //#define                PWM3_OUTPUT_INVERSE                        PNP|=0x08
  62. //#define                PWM2_OUTPUT_INVERSE                        PNP|=0x04
  63. //#define                PWM1_OUTPUT_INVERSE                        PNP|=0x02
  64. //#define                PWM0_OUTPUT_INVERSE                        PNP|=0x01
  65. //#define                PWM_OUTPUT_ALL_INVERSE        PNP=0xFF
  66. //#define                PWM5_OUTPUT_NORMAL                        PNP&=0xDF
  67. //#define                PWM4_OUTPUT_NORMAL                        PNP&=0xEF
  68. //#define                PWM3_OUTPUT_NORMAL                        PNP&=0xF7
  69. //#define                PWM2_OUTPUT_NORMAL                        PNP&=0xFB
  70. //#define                PWM1_OUTPUT_NORMAL                        PNP&=0xFD
  71. //#define                PWM0_OUTPUT_NORMAL                        PNP&=0xFE
  72. //#define                PWM_OUTPUT_ALL_NORMAL                PNP=0x00
  73. ////--------- PWM type define ------------------------------------
  74. //#define                PWM_EDGE_TYPE                                                PWMCON1&=~SET_BIT4
  75. //#define                PWM_CENTER_TYPE                                        PWMCON1|=SET_BIT4
  76. ////--------- PWM mode define ------------------------------------
  77. //#define                PWM_IMDEPENDENT_MODE                PWMCON1&=0x3F
  78. //#define                PWM_COMPLEMENTARY_MODE        PWMCON1|=0x40;PWMCON1&=0x7F
  79. //#define                PWM_SYNCHRONIZED_MODE                PWMCON1|=0x80;PWMCON1&=0xBF
  80. //#define         PWM_GP_MODE_ENABLE                        PWMCON1|=0x20
  81. //#define                PWM_GP_MODE_DISABLE                        PWMCON1&=0xDF
  82. ////--------- PMW interrupt setting ------------------------------
  83. //#define                PWM_FALLING_INT                                        PWMCON0&=0xF3
  84. //#define                PWM_RISING_INT                                        PWMCON0|=0x04;PWMCON0&=0xF7
  85. //#define                PWM_CENTRAL_POINT_INT                PWMCON0|=0x08;PWMCON0&=0xFB
  86. //#define                PWM_PERIOD_END_INT                        PWMCON0|=0x0C
  87. ////--------- PWM interrupt pin select ---------------------------
  88. //#define                PWM_INT_PWM0                                                PWMCON0&=0xFC
  89. //#define                PWM_INT_PWM2                                                PWMCON0|=0x01;PWMCON0&=0xFD
  90. //#define                PWM_INT_PWM4                                                PWMCON0|=0x02;PWMCON0&=0xFE
  91. //#define                PWM_INT_PMW6                                                PWMCON0|=0x03
  92. ////--------- PWM Dead time setting ------------------------------
  93. //#define         PWM45_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x04;EA=BIT_TMP
  94. //#define         PWM34_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x02;EA=BIT_TMP
  95. //#define         PWM01_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x01;EA=BIT_TMP
  96. #endif
  97. void PWM_DEAD_TIME_VALUE(UINT16        DeadTimeData)
  98. {
  99.         UINT8 deadtmphigh,deadtmplow;
  100.         deadtmplow = DeadTimeData;
  101.         deadtmphigh = DeadTimeData>>8;
  102.         BIT_TMP = EA;
  103.         if (deadtmphigh==0x01)
  104.         {
  105.                 EA = 0;
  106.                 TA = 0xAA;
  107.                 TA = 0x55;
  108.                 PDTEN|=0x10;
  109.         }
  110.         TA = 0xAA;
  111.         TA = 0x55;
  112.         PDTCNT = deadtmplow;
  113.         EA = BIT_TMP;
  114. }
  115. //------------------- PWM Define End ------------------------------
  116. /************************************************************************************************************
  117. *    Main function
  118. *                 PWM4 P0.5 simple output a 2.7KHz 1/4high duty signal
  119. ************************************************************************************************************/
  120. void main(void)
  121. {
  122.     Set_All_GPIO_Quasi_Mode;
  123. /*-----------------------------------------------------------------------------------------------------------------
  124.         PWM frequency         = Fpwm/((PWMPH,PWMPL)+1) = (16MHz/8)/(0x7CF+1) = 1KHz (1ms)
  125.         PWM4 high duty         = PWM4H,PWM4L = 0x01CF = 1/4 PWM period
  126.         PWM0 high duty         = PWM0H,PMW0L = 0x03CF = 1/2 PWM period
  127.         Dead time                         = 0x1FF <PDTEN.4+PDTCNT[7:0]>/Fsys = 0x1FF/Fsys = 512/16000000 = 32 us (max value)
  128. -----------------------------------------------------------------------------------------------------------------*/
  129.                 PWM0_P12_OUTPUT_ENABLE;
  130.                 PWM1_P11_OUTPUT_ENABLE;
  131.                 PWM4_P01_OUTPUT_ENABLE;
  132.                 PWM5_P15_OUTPUT_ENABLE;
  133.
  134.                 PWM_COMPLEMENTARY_MODE;                                        //Only this mode support deat time function
  135.                 PWM_CLOCK_DIV_8;
  136.                 PWMPH = 0x07;
  137.                 PWMPL = 0xCF;
  138.                 PWM0H = 0x03;
  139.                 PWM0L = 0xCF;
  140.                 set_SFRPAGE;        // PWM4 and PWM5 duty value need set SFPPAGE 1
  141.                 PWM4H = 0x01;
  142.                 PWM4L = 0xCF;
  143.                 clr_SFRPAGE;
  144.
  145.                 PWM01_DEADTIME_ENABLE;
  146.                 PWM45_DEADTIME_ENABLE;
  147.                 PWM_DEAD_TIME_VALUE(0x1FF);                        //value never over 0x1FF
  148.
  149. //Please always setting Dead time if needed before PWM run.
  150.     set_LOAD;
  151.     set_PWMRUN;
  152.                 while(1);
  153. }
zhuotuzi 发表于 2018-6-28 18:19 | 显示全部楼层
这个例子好,这么多宏,不用去查手册了。
天灵灵地灵灵 发表于 2018-6-29 11:02 | 显示全部楼层
如果所有的数字都用宏表示就更容易懂了。
zhuomuniao110 发表于 2018-6-29 14:49 | 显示全部楼层
宏定义的内容还是需要结合手册才能看懂。
陈乐乐 发表于 2018-7-11 10:17 | 显示全部楼层
支持一下楼主
mfc4143 发表于 2018-7-22 21:50 | 显示全部楼层
这个deadtime什么意思?
tianxj01 发表于 2018-7-23 08:28 | 显示全部楼层
这个deadtime什么意思?
dead 死 time 时间
合起来死区时间
zhuomuniao110 发表于 2018-7-23 10:32 | 显示全部楼层
这个deadtime什么意思?
死区时间长度。手册有提到这个概念,保护电机的
mfc4143 发表于 2018-7-23 11:35 | 显示全部楼层
在问一个,这个芯片哪个引脚不能作为输入 多达17个标准通用管脚,另外还有1个只能做输入的管脚,没找到哪个
dongnanxibei 发表于 2018-7-24 11:09 | 显示全部楼层
在问一个,这个芯片哪个引脚不能作为输入 多达17个标准通用管脚,另外还有1个只能做输入的管脚,没找到哪 ...
所有I/O引脚(除P2.0)可以被软件独立配置成四种I/O模式中的一种。
dongnanxibei 发表于 2018-7-24 11:10 | 显示全部楼层
还有你可以参考头文件SFR——Macro.h
里面只有定义P0,P1,16个IO加P30管脚1个IO,共17个IO的定义,没有P20的
dongnanxibei 发表于 2018-7-24 11:11 | 显示全部楼层
这是IO的说明。
mfc4143 发表于 2018-7-25 08:19 | 显示全部楼层
zhuomuniao110 发表于 2018-7-25 13:57 | 显示全部楼层
如果能做成个封装的函数,随意调用就爽了,每次搞一堆麻烦。
稳稳の幸福 发表于 2018-7-25 19:10 | 显示全部楼层
支持楼主,这个PWM用好了控制电机很棒
mfc4143 发表于 2018-7-27 17:55 | 显示全部楼层
为啥有的引脚不论给1还是0,输出都是1.7V,不是P2.0
