[ARM入门] VS-RK3399在android下面把声音放到最大时候,播放器自动退出...
991|0
 楼主| 3026969227QQ 发表于 2018-11-27 10:32 | 显示全部楼层 |阅读模式
VS-RK3399在android下面把声音放到最大时候,播放器自动退出问题
VS-RK3399 在android下面把声音放到最大时候,播放器自动退出问题。使用系统自带的Video.apk播放,当声音放到最大时候,播放视频过一会后自动退出,影响ADC采样,干扰了物理键,返回一个back键出来,刚好Video.apk有处理返回键的相应,导致播放时候退出。
修改方法:
\kernel\arch\arm64\boot\dts\rockchip\rk3399-android.dtsi
rk_key: rockchip-key {
                compatible = "rockchip,key";
                status = "okay";
                io-channels = <&saradc 1>;
                vol-up-key {
                        linux,code = <115>;
                        label = "volume up";
                        rockchip,adc_value = <1>;
                vol-down-key {
                        linux,code = <114>;
                        label = "volume down";
                        rockchip,adc_value = <170>;
                power-key {
                        gpios = <&gpio0 5 GPIO_ACTIVE_LOW>;
                        linux,code = <116>;
                        label = "power";
                        gpio-key,wakeup;
#if 0
                menu-key {
                        linux,code = <59>;
                        label = "menu";
                        rockchip,adc_value = <746>;
                home-key {
                        linux,code = <102>;
                        label = "home";
                        rockchip,adc_value = <355>;
                back-key {
                        linux,code = <158>;
                        label = "back";
                        rockchip,adc_value = <560>;
                camera-key {
                        linux,code = <212>;
                        label = "camera";
                        rockchip,adc_value = <450>;
#endif
按上面操作,把back键去掉
