 1. 下载 boost 代码,解压
 2. 在当前目录下执行:
 D:\tools\boost_1_69_0>bootstrap.bat mingw
 然后当前目录会有文件生成:
 Building Boost.Build engine
Bootstrapping is done. To build, run:
    .\b2
To adjust configuration, edit 'project-config.jam'.
Further information:
    - Command line help:
    .\b2 --help
    - Getting started guide:
    http://boost.org/more/getting_started/windows.html
    - Boost.Build documentation:
    http://www.boost.org/build/doc/html/index.html
让后用生成的 b2.exe:
 D:\tools\boost_1_69_0>b2.exe --prefix=d:\tools\boost_1_69_0 --build-type=complet
e toolset=gcc threading=multi
