[STM32F4] 大家好!请问有哪位做过STM32F4与SPARTAN6的通信?
950|6
 楼主| wangjiahao88 发表于 2019-8-7 13:56 | 显示全部楼层 |阅读模式
发现另一个小板子,不知道哪里有卖的!
 楼主| wangjiahao88 发表于 2019-8-7 14:01 | 显示全部楼层
Power consumption: 3 Watts*) @ 3.3V (alternate VIO for the
FPGA is 2.5V (Bank 0 & 2))
Micro-Controller: STM32F417 (F407, F437 optional )
FPGA: Spartan-6 XC6SLX16 (XC6SLX45 optional)
External Memory: 128 MBytes DDR3, 64 Mbit SPI flash
I/O: Up to 130 general purpose I/O pins, supporting different
I/O standards and protocols (see text)
Physical Dimensions: 67.6 x 30.0 x 6mm (SO-DIMM200)
Weight: approx. 6grams
Matching Socket: e.g., TE Connectivity 1473005-4
Bottom/Top Component Height: 2.0/2.0mm (max.)
*) depending on the application
 楼主| wangjiahao88 发表于 2019-8-7 14:02 | 显示全部楼层
感觉这个设计,很不错!
谁知道哪家卖类似的 STM32 和 FPGA 通讯的开发板?
请麻烦告知一下!
谢谢!
 楼主| wangjiahao88 发表于 2019-8-7 14:03 | 显示全部楼层
XynergyXS combines STMicroelectronics‘ STM32F417
controller, based on ARM® Cortex™-M4, with a Xilinx
Spartan-6 low-cost FPGA XC6SLX16 The controller’s
FSMC interface is used for parallel 16-bit connection to
the FPGA ensuring high-speed data transfer between the
two devices. The STM32F417 core can be clocked at
up to 168 MHz and has up to 1 MB on-chip flash and
192 KB on-chip SRAM. In addition, the 1Gb (64M x 16)
DDR-3 memory, which is connected to the FPGA, can be
made transparent via the FSMC bus, allowing the
controller to use it like external memory.
The micro-controller of the XynergyXS provides
numerous communications interfaces, including 10/100
Ethernet with PHY, USB-OTG, CAN (two channels), one
SPI, one COM-Port (RX/TX only), I²C (two channels), an
SDIO port, seven ADC channels, two DAC channels and
up to 21 general purpose I/O lines. All interface signals
are available at the 200-pin SO-DIMM edge connector.
