- * [url=home.php?mod=space&uid=288409]@file[/url] 1.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.03
- * [url=home.php?mod=space&uid=212281]@date[/url] 2019/08/18-12:56:20
- * [url=home.php?mod=space&uid=247401]@brief[/url] NuMicro generated code file
- * Copyright (C) 2013-2019 Nuvoton Technology Corp. All rights reserved.
- MCU:M4TKLE6AE(LQFP48)
- Base Clocks:
- Enabled-Module Frequencies:
- FMCIDLE=Bus Clock(HCLK):Disabled/Engine Clock:
- ISP=Bus Clock(HCLK):Disabled/Engine Clock:
- WDT=Bus Clock(PCLK):Disabled/Engine Clock:
- WWDT=Bus Clock(PCLK):Disabled/Engine Clock:
- #include "M451Series.h"
- Define HXT clock.
- Please locate and modify the real one in your project.
- Otherwise, the project may fail to build.
- #define __HXT (0UL) /*!< High Speed External Crystal Clock Frequency */
- * @brief This function updates clock registers to fulfil the configuration
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- void SYS_Init()
- /* Init System Clock */
- //CLK->PWRCTL = (CLK->PWRCTL & ~(0x0000000Ful)) | 0x0000001Ful;
- //CLK->PLLCTL = (CLK->PLLCTL & ~(0x000FFFFFul)) | 0x0005C02Eul;
- //CLK->CLKDIV0 = (CLK->CLKDIV0 & ~(0x00FF0FFFul)) | 0x00000000ul;
- //CLK->CLKDIV1 = (CLK->CLKDIV1 & ~(0x000000FFul)) | 0x00000000ul;
- //CLK->CLKSEL0 = (CLK->CLKSEL0 & ~(0x000000FFul)) | 0x0000003Ful;
- //CLK->CLKSEL1 = (CLK->CLKSEL1 & ~(0xF3777703ul)) | 0xB377770Ful;
- //CLK->CLKSEL2 = (CLK->CLKSEL2 & ~(0x000000FFul)) | 0x000000ABul;
- //CLK->CLKSEL3 = (CLK->CLKSEL3 & ~(0x00000203ul)) | 0x00000003ul;
- //CLK->AHBCLK = (CLK->AHBCLK & ~(0x0000809Eul)) | 0x00008004ul;
- //CLK->APBCLK0 = (CLK->APBCLK0 & ~(0x1D0F73FFul)) | 0x00000001ul;
- //CLK->APBCLK1 = (CLK->APBCLK1 & ~(0x02031001ul)) | 0x00000000ul;
- //CLK->CLKOCTL = (CLK->CLKOCTL & ~(0x0000007Ful)) | 0x00000000ul;
- //SysTick->CTRL = (SysTick->CTRL & ~(0x00000005ul)) | 0x00000000ul;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable clock source */
- CLK_EnableXtalRC(CLK_PWRCTL_LIRCEN_Msk|CLK_PWRCTL_HIRCEN_Msk|CLK_PWRCTL_LXTEN_Msk|CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for clock source ready */
- CLK_WaitClockReady(CLK_STATUS_LIRCSTB_Msk|CLK_STATUS_HIRCSTB_Msk|CLK_STATUS_LXTSTB_Msk|CLK_STATUS_HXTSTB_Msk);
- /* If the defines do not exist in your project, please refer to the related clk.h in the Header folder appended to the tool package. */
- /* Set HCLK clock */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Set PCLK-related clock */
- CLK->CLKSEL0 = CLK->CLKSEL0 & ~CLK_CLKSEL0_PCLK0SEL_Msk;
- CLK->CLKSEL0 = CLK->CLKSEL0 & ~CLK_CLKSEL0_PCLK1SEL_Msk;
- /* Enable IP clock */
- CLK_EnableModuleClock(FMCIDLE_MODULE);
- CLK_EnableModuleClock(ISP_MODULE);
- CLK_EnableModuleClock(WDT_MODULE);
- CLK_EnableModuleClock(WWDT_MODULE);
- /* Set IP clock */
- CLK_SetModuleClock(WDT_MODULE, CLK_CLKSEL1_WDTSEL_LIRC, MODULE_NoMsk);
- CLK_SetModuleClock(WWDT_MODULE, CLK_CLKSEL1_WWDTSEL_HCLK_DIV2048, MODULE_NoMsk);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
- SystemCoreClockUpdate();
- /* Lock protected registers */
- SYS_LockReg();
- return;
- /*** (C) COPYRIGHT 2013-2019 Nuvoton Technology Corp. ***/
