[技术问答] M0516 EINT1无法进入中断
803|3
 楼主| 撒打算的节目 发表于 2019-8-22 12:37 | 显示全部楼层 |阅读模式
哪位大佬帮我看一下,到底我哪里设置错了,死也进不去中断
P3_MFP                        EQU                0x5000003C
P33                                EQU                0X5000426C
P32                                EQU                0x50004268
P3_IEN                        EQU                0x500040DC
P3_ISRC                        EQU                0x500040E0
Stack_Size      EQU     0x00000200
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000000
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
__Vectors       DCD     __initial_sp              ; Top of Stack
                DCD     Reset_Handler             ; Reset Handler
                                DCD     0                                 ; NMI Handler
                DCD     0                                          ; Hard Fault Handler
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                                      ; SVCall Handler
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                                        ; PendSV Handler
                DCD     0                                            ; SysTick Handler
                ; External Interrupts
                                                  ; maximum of 32 External Interrupts are possible
                DCD     0
                DCD     0
                DCD     0
                DCD     EINT1_IRQHandler
                AREA    |.text|, CODE, READONLY
; Reset Handler
                ENTRY
Reset_Handler
                EXPORT  Reset_Handler             [WEAK]
                                ;EXPORT        TABLE
                ;IMPORT  SystemInit
                ;IMPORT  main
                LDR     R0, =0x50000100
                ; Unlock Register
                LDR     R1, =0x59
                STR     R1, [R0]
                LDR     R1, =0x16
                STR     R1, [R0]
                LDR     R1, =0x88
                STR     R1, [R0]
                ; Init POR
                LDR     R2, =0x50000024;
                LDR     R1, =0x00005AA5
                STR     R1, [R2]
                                ;        Init Clock
                                LDR                R2, =0x5000021C;CLKSEL2
                                LDR                R1, =0x000000A8;
                                STR                R1, [R2]
                                LDR                R2, =0x50000200;PWRCON
                                LDR                R1, =0x00000014;22M_OSC_EN
                                STR                R1, [R2]
                                LDR                R2, =0x50000210;CLKSEL0
                                LDR                R1, =0x0000001A;HCLK from        PLL
                                STR                R1, [R2]
                                ;LDR                R2, =0x50000214;CLKSEL1
                                ;LDR                R1, =0x00000210
                                ;STR                R1,[R2];SPI Clock from PLL,TIMER0 Clock from HCLK
                                ;LDR                R2, =0x50000208;APBCLK
                                ;LDR                R1, =0x00001004;SPI0CLK_EN,TIMER0_EN
                                ;STR                R1, [R2]
                                LDR                R2, =0x50000220;PLLCON
                                LDR                R1,        =0x0008D25F;48.25MHz
                                STR                R1, [R2]
                ; Lock register
                MOVS    R1, #0
                STR     R1, [R0]
                                ;TIME0 Init
                                ;LDR                R2,=0X40010000
                                ;LDR                R1,=0x70100010;TIME0-PUTOUT
                                ;STR                R1,[R2]
                                ;LDR                R2,=0X40010004
                                ;LDR                R1,=0x00000003;
                                ;STR                R1,[R2]
                                ;System Init
                                ;LDR                R2,=0X50000034;P1_MFP
                                ;LDR                R1,=0x0000F000;SPI0        复用
                                ;STR                R1,[R2]
                                ;LDR                R2,=0X5000003C;P3_MFP
                                ;LDR                R1,=0x00004010;
                                ;STR                R1,[R2]
                                LDR                R4,=P32
                                LDR                R5,=P33
NVIC_INIT
                                ; NVIC Init
                                LDR     R2, =0xE000E100;
                LDR     R1, =0x00000008
                STR     R1, [R2]
                                LDR     R2, =P3_IEN;EINT1_EN
                LDR     R1, =0x00100000
                STR     R1, [R2]
                                LDR     R2, =P3_MFP;EINT1_EN
                LDR     R1, =0x00000010
                STR     R1, [R2]
                ;LDR     R0, =SystemInit
                ;BLX     R0
startloop
                                ; IO Init
                LDR                R2, =0x500040C0;
                                LDR                R1, =0x0000FF3F;
                                STR                R1, [R2]
                                LDR     R2, =P3_ISRC;
                ;LDR     R1, =0x00000010
                ldr     R1, [R2]
                                MOVS        R0,#0X00
                                MOVS        R1,#0X01
                                MOVS        R3,#0X16
                                MOVS        R6,#0
                                STR                R0,[R4]
                                B                startloop
EINT1_IRQHandler
                                MOVS        R0,#0X00
                                MOVS        R1,#0X01
                                STR                R1,[R4]
                                STR                R0,[R4]
                                BL                mainloop
                                END
main部分就不贴出来了,我调试的时候死也进不了中断,不知道什么原因
 楼主| 撒打算的节目 发表于 2019-8-22 14:09 | 显示全部楼层
emmm,已解决,p33是0x08,不是0x10
643757107 发表于 2019-8-24 10:30 | 显示全部楼层
喔,厉害,还有人用汇编
xuanhuanzi 发表于 2019-8-24 10:35 | 显示全部楼层
是的,芯片一般是没有问题的。
