波形显示
474|0
 楼主| 丑帅丑帅的 发表于 2018-7-10 16:06 | 显示全部楼层 |阅读模式
void Show_Wave_Fun(float MAX,float MIN,u16 OriginalPoint_X,u16 OriginalPoint_Y,float Volue,u16 high)      //MAX:数据最大值, MIN:数据最小值, OriginalPoint_X:原点X,  OriginalPoint_Y:原点Y坐标, Volue:数据值, high:坐标轴高度
         u16 X,Y;
         u8 i;
   float Temp=0;
   static u16 X_temp=0;
   static u16 High=0;
   static u16 Mode0_volue[200][1]={0};
         POINT_COLOR=BLACK;
   Temp = MAX-MIN;
   High = high;
        LCD_DrawLine(OriginalPoint_X,OriginalPoint_Y,200+OriginalPoint_X,OriginalPoint_Y);
  if(OriginalPoint_Y>=High)
    LCD_DrawLine(OriginalPoint_X,OriginalPoint_Y,OriginalPoint_X,OriginalPoint_Y-High);
        else
                LCD_DrawLine(OriginalPoint_X,OriginalPoint_Y,OriginalPoint_X,0);
  Y=(u16)((Volue-MIN)*High/Temp);
  for(i=0,X=OriginalPoint_X; i<=X_temp; X++,i++)
    LCD_Fast_DrawPoint(X,OriginalPoint_Y - Mode0_volue[0],WHITE);
  if(X_temp==200-1)
                        for(i=0;i<=X_temp;i++)
                                if(i+1<200)
                                                Mode0_volue[0]=Mode0_volue[i+1][0];
  Mode0_volue[X_temp][0]=Y;
                LCD_Fast_DrawPoint(X,(u16)(OriginalPoint_Y-Mode0_volue[0]),RED);
  if(X_temp<200-1)
                        X_temp++;
