[嵌入式linux] 进入控制台后为什么还打印出GTP信息
620|0
 楼主| nuc990 发表于 2021-1-31 11:25 | 显示全部楼层 |阅读模式
  1. fec 20b4000.ethernet eth0: Freescale FEC PHY driver [NS DP83848C 10/100 Mbps PHY] (mii_bus:phy_addr=20b4000.ethernet:05, irq=-1)
  2. IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  3. fec 2188000.ethernet eth1: Freescale FEC PHY driver [NS DP83848C 10/100 Mbps PHY] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
  4. IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
  5. [root@IoT-A6G2C ]# <<-GTP-INFO->> System resume.
  6. <<-GTP-INFO->> GTP wakeup sleep.
  7. <<-GTP-INFO->> Driver send config.
  8. fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
  9. IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
明明已经进入了控制台[root@IoT-A6G2C ]# 了,然后又打印出触摸屏信息。为什么回这样?谢谢
